W113 Pagoda SL Group => General Discussion => Topic started by: Chad on November 27, 2005, 16:14:50
Title: List for No Longer Available Parts Lobby
Post by: Chad on November 27, 2005, 16:14:50
(This is an idea that George, Robert Geco, and other active forum members have suggested within the forum discussion recently.)
NO LONGER AVAILABLE PARTS (NLA) LOBBY
Go ahead and list your favorite No Longer Available (NLA) part for lobbying with Classic Center and the usual list of quality suppliers that we use (Millers, Buds, GAHH, many others).  Perhaps during the course of parts ordering many of us do for restoration/ maintenance/ upkeep/ tinkering with can email, phone and write to sound the word and the market to those who certainly do want to know this info to produce it at a reasonable price. These suppliers do simply want to sell us things.
Add each new and unique item to the list with a number prior to it to help with a running talley.
Perhaps this will help every forum member to mention this every time we communicate with the suppliers. Like writing your congressman. It can help the bulk of w113 owners. Cheers and maybe some good can come of it.
-CD-
1967 230SL, 113.042 10
Title: Re: List for No Longer Available Parts Lobby
Post by: Chad on November 27, 2005, 16:15:22
(1) Diamond pattern firewall pad in environmentally friendly material.
-CD-
Post by: Cees Klumper on November 27, 2005, 18:02:10
Great idea Chad. As president of the Pagoda Group I can take this list to Daimler-Chrysler, perhaps teaming up with the German Pagoda club and the German-language W113 forum, to lobby. The main consideration for parts suppliers is having some indication of demand out there, and this is a great way to gauge that.
Post by: iceberg on November 27, 2005, 18:14:43
I agree with Chad abou the firewall pad and would also like to add:
(5) The rubber stoppers between the door panels and the door frame.
H
Post by: Chad on November 27, 2005, 18:44:12
(2) Rubber stoppers (door to door frame) - as per iceberg
(3) Sunvisors (reasonably priced, not a NLA, but World UPH inquired with us about it and don't know if we followed up)
(4) 5 speed transmission (just kidding, but there are probably some common repair parts that you lucky dogs with the ZF could use)
-CD-
Post by: George Des on November 27, 2005, 19:29:31
Cees/Chad,
I second the diamond pattern firewall pad and there are many others--the sun visors for all the different 113s come to mind. You are right about the ZF 5 speed. At some point all of us who have them are going to need some parts for this. Input shafts, synchronizer rings and assorted aluminum casting parts such as the rear cover plate as well as the gears. Many of the other parts are fairly common bearings, seals and hardware and are readily available. Tailight lenses in all their different configurations will always be needed. The internal parts of the European headlights, particularly the top reflector and the darn clips that hold the glass lens to the h/l assembly. Comprehensive repair parts kits for both style fuel pumps would also help. If Cees can make the contact over there that would be great--I hope others will do as I have and go directly to the Classic Center with a request--all of this may come to nothing, but one never knows until one tries!
George Des
Post by: Mike Hughes on November 28, 2005, 14:51:03
I'd suggest:
(6) rubber floormats for 230SL, in all of the originally available colors, and
(7) original style polished stainless wiper blades for same!
Post by: Bob G ✝︎ on November 28, 2005, 16:57:35
The little rubber stop that goes into the bottom rear of the hard top. Reproduce the red tailights for early 113 chassies. Dash peices new and sun visors for the 280SL. The correct fire wall diamond cut material for the fire wall.
Post by: Chad on November 28, 2005, 20:56:37
I'd like to see those rubber floor mats for 230 also. They are very period feel, even many of the Astons from the era had rubber mats also. Are we absolutely sure that they are NLA??  I have never inquired.
And stainless wiper blades also!  Again, before adding to the list, are we sure that SLS doesn't carry?
-CD-
Post by: gugel on November 28, 2005, 21:48:38
Early 230SL sunvisors, with the mirror in the right hand one.  I think sunvisors are available, but not with the mirror.
I'd also like to see the rubber floor and trunk mats for the 230SL, in the original colors.
Under dash cladding, also in the original colors.  I've been able to find it only in black.
230SL fuel injection pump thermostat and housing, for a reasonable price.  (I think the thermostat is available, for about $500!)
The BBB in English.
Chris Earnest
Post by: TA250SL on November 28, 2005, 22:18:31
Here are a few more NLA items:
ignition key blanks,
passenger door pull handle,
early-style window crank inserts in all colors,
Euro front turn indicator reflectors
Early 1967 250SL
Euro version
Los Angeles
Post by: pagode.info on November 29, 2005, 01:06:17
The first thing they should do is to put
the EPC(Electronic Parts Catalogue) and
the parts price list (both available on
CD at any Merc dealer)online now.
Lots of parts are still available, but
nobody knows. (Same with 107)
Have a nice day,
www.pagode.info
Post by: waltklatt on November 29, 2005, 10:15:12
How about the data plates with the option codes and VIN #'s.   Especially the older versions which are more squarish and sit on the firewall and the hand hood release bracket.  Also the small rubber bumpers that sit on the ridge that runs across the firewall(the ones out there are close to the originals).
How about the original 5.5x14 rims with the #113 stamped onto them as well as the 5.5x15 rims too.  I have tried the 15 inchers on my SL and it looks good with extra clearance and would help in the economy too.
Umm, hardtops with sunroofs?  Skiracks?, and other rare options.  Can't a guy dream?
Walter Klatt
1967 220SL diesel
1963 230SL gas nearly stripped
Post by: jmela on November 29, 2005, 11:40:50
White plastic automatic shift guide insert at a non-extortionate price.
Post by: 113gray on November 29, 2005, 12:53:48
Yeah, 5 speed ZF parts would be wonderful!     -JP-
Post by: rwmastel on November 30, 2005, 19:49:50
As Chad requested, please use a number to identify your request.  We need to keep this organized.  Please go back and edit your posts to look like the first couple replies.  That is:
(8)  Parts request
(9)  Next parts request
(10)  Some other part
Post by: Chad on December 01, 2005, 19:45:58
I've just been jotting them down on a notepad along the way. Mentioned to four suppliers already.  I have no idea what to suggest regarding ZF 5speed , but the others are mentioned and they seemed very interested.
Make the list, *and* mention the list to the suppliers, if you think it helpful and you're interested.
Rodd's reminder is very helpful, I think.
-CD-
1967 230SL
Post by: hauser on December 04, 2005, 22:47:01
Here's my list
original style/quality carpeting
SS screw packages
plastic moulding under chrome strip between tail lights
original firewall pad
tool kit
bosch euro light lenses ( no tooling marks) and other parts
rubber bumpers for hood
original quality leather
Post by: n/a on January 13, 2006, 12:20:55
Yes, my father and I are doing a restore and we need a DRIVERS SIDE SUNVISOR. I have seen beaten and battered ones for $400-$500
I have been mostly looking on E-bay but not having very much luck. Anyone have any ideas of where to get one for not a whole lot of money?
In reasonable shape? 1965 Convert 230SL // off white tanish Colored Interior
Post by: KevinC on January 13, 2006, 17:25:49
Try this site...www.sls-hh.de
About $250.00 US but brand new..worth it if you are restoring.
Kevin
Download Attachment: (http://images/icon_paperclip.gif) MB Sunvisor LH 1.JPG (http://www.sl113.org/forums/uploaded/kevinc/2006113182243_MB%20Sunvisor%20LH%201.JPG)
49.04 KB
Download Attachment: (http://images/icon_paperclip.gif) MB Sunvisor LH 2.jpg (http://www.sl113.org/forums/uploaded/kevinc/200611318236_MB%20Sunvisor%20LH%202.jpg)
14.59 KB
Download Attachment: (http://images/icon_paperclip.gif) MB Sunvisor LH 3.jpg (http://www.sl113.org/forums/uploaded/kevinc/2006113182329_MB%20Sunvisor%20LH%203.jpg)
21.12 KB
Kevin Caputo
Boca Raton, FL
1967 230 SL Automatic
670 Light Ivory
113 Bronze/Brown MB Tex
Post by: Chad on January 13, 2006, 19:35:08
Kay just started a new thread about sourcing these for cheaper, possibly. I will be interested and following that progress through the spring.
If nothing comes of it I think that the SLS price is the lowest I have found also.
I remember World UPH was inquiring of our interest in the sunvisors, but I don't think they have put the product up for sale yet.
Post by: Chad on January 13, 2006, 19:39:59
BTW, I just wanted to mention that I had thought the original 230 style MB textured vinyl was NLA, and I suppose it is.... however, the vinyl set I ordered (GAHH) is virtually identical (basketweave and texture/finish) to the vinyl seat covers that were original to the car.  If anyone has a 230 with vinyl originally on it then I would say that GAHH makes a product that is very satisfying if you want to keep the seats vinyl as original.
Post by: Chad on January 31, 2006, 00:16:17
Apparently the 230 SL chrome rear view mirror (center one inside the windscreen) is also NLA, as far as I can tell as I am trying to find one for replacement.
Post by: Bob G ✝︎ on January 31, 2006, 16:05:39
1) firewall pad orginal material & dimond pattern
2) old style red taillights with chrome bezel not glued but remaufactured
3) an assortment of chrome screws always asked for grill. door trim screws
4) dash pad parts offered again.
6)correct heel pad with star for carpet sets
7)hood & door bumpers correct old style
8)hard top handle sets with bearing
9better tecnhical literature
10) sunvisors for 230SL & 280SL
11) hard top rubber seals & correct headliner kit
12) Get Tom Hanson back at the parts counter were we can fine him
Post by: Chad on January 31, 2006, 20:16:46
12) chrome rear view mirror center 230SL style
Do you mean "fine" or "find," Bob??(' :) ')
Post by: rwmastel on January 31, 2006, 21:01:21
[:0]  I hope he meant "find"!!
 8)  I think Bob is actually one of Tom's biggest fans.
Post by: DavidAPease on February 01, 2006, 13:08:06
Chad,
I don't know if you're looking for a brand new interior mirror, but Mike Passarelli (ranchomerced) has just listed a used one that he says works for the 230SL on eBay:
http://cgi.ebay.com/ebaymotors/Mercedes-Benz-Rear-View-Mirror-230SL-250SL_W0QQcmdZViewItemQQcategoryZ34197QQitemZ4609382710QQrdZ1
-David Pease
'66 French 230SL
Post by: Bob G ✝︎ on February 01, 2006, 14:31:36
I was contacted reguarding weather stripping for the three windows on the hard top. To my amazment they are availible at a price:
1136700039back glass weather seal $100.00
1133670139 left side glass rubber seal $75.00
11336700239 right side glass rubber seal $75.00
Chrome release handles for hard top 1137900568 & 0665
Cost each $384.00 Holly MCnuggets Bat Man.
Prices quoted by the classic center in New Jersery.
Post by: Bob G ✝︎ on February 01, 2006, 16:45:34
I have several heros when it comes to slaying the big mercedes-benz parts repar. Yes Tom Hanson and many other people helped me with my 280SL. I am a fan of anyone who can stand to be in the automotive business as many years as Tom Hanson and still be married:
Here is to you Tom !!
Post by: Chad on February 01, 2006, 18:38:52
The vinyl seat basketweave from GAHH turned out to be pretty close to what was original. Close enough for me. I think only GAHH produces this (of course other suppliers will often sell you GAHH produced products for cheaper).
Download Attachment: (http://images/icon_paperclip.gif) basketweave.jpg (http://www.sl113.org/forums/uploaded/chad/200621193915_basketweave.jpg)
56 KB
Post by: pagode.info on February 04, 2006, 00:32:41
Both sunvisors are still available at Your local Merc dealer !
If You discover new original visors in catalogues or internet,
what do You think they come from ?
Have a nice day,
Tom  :)
part #`s:
230 SL: 113 810 0110 8001 lt beige
230 SL: 113 810 0210 8001 rt-beige
280 SL: 113 810 0710 8001 lt-beige
280 SL: 113 810 0810 8001 rt-beige
Post by: Chad on February 04, 2006, 23:41:23
Hi Tom,
I think we all pretty much realize they are available from several sources, they are not NLA.  Thanks for the parts numbers. It is very helpful to make sure that we are getting the correct style for the model we have.  We also are aware of the present cost of the sunvisors available.
Post by: psmith on April 03, 2006, 22:34:11
Wasn't there an option for headers on the 230's?  I think Dr. Dan has them on his car.  That would be a nice reissue.
Pete S.
Post by: rwmastel on April 04, 2006, 16:44:37
Pete,
I think they were simply standard up to a particular serial number, then changed to our "normal" exhaust headers.
Post by: psmith on April 04, 2006, 21:41:04
Maybe it's a terminology thing, I know just enough half truths to be 2/3 dangerous, but I've always thought of headers to be individual pipes to each cylinder that merge after enough distance to reduce back pressure.  What's on my car ('67) is more of an exhaust manifold.  Did the early 230's really have headers?  Are they still available?
Pete S.
Post by: rwmastel on April 09, 2006, 19:17:29
We are on the same page regarding the term "headers" or "header pipes".  Yes, they were standard on the 230SL, up to a particular serial number, which I don't know.  I think they are very difficult to find now.  There was a recent link posted to an e-Bay auction with 3 or 4 Pagodas, one showing header pipes on an engine.
Post by: 66andBlue on July 29, 2006, 09:38:18
What happened to the NLA Lobby and "the list"?
The German language Pagoda site and the MBCCI [Mercedes Classic Car Club International at http://www.mercedes-benz-clubs.com/] have started a similar Parts with Problems list, divided into sub-categories:
1. ZZNL - which means "currently not available"
2. NML = NLA [D-C code C47]
3. shoddy material or part not fitting
4. overpriced at D-C compared to open market.
The hope is that by compiling such a list and making it semi-public on the MBCCI web site that it may pressure D-C to be less "bottom-line" oriented and more helpful to owners of classic cars.
It appears that the biggest hurdle to get the list going is finding the correct part number.
Perhaps we should join their efforts to have an EPC [electronic parts catalog] that is freely accessible to registered club or group members.
Post by: vincesy on September 24, 2006, 02:01:02
Is it true that the rheostat is no longer available?
Is there a quick and easy fix for this?  My tachometer and everything else is bright enough but the speedometer is dim.
Has anyone tried bypassing the rheostat completely, sacrificing what I think is a hardly used dimmer function, for better visibility and simplicity?
Post by: hauser on September 24, 2006, 10:29:56
Vincesy,  That is exactly what I did with mine. These dimmers are the greatest and sometimes it's best just to bypass it.  If my dimmer did work I'd have it turned to the brightest setting since anything less just isn't bright enough for me.
Post by: ZwoachtzigSL on September 24, 2006, 23:30:46
W113 Problemteile Liste - Problem Spare-Parts-List
Hello Friends.
I provided the first W113 "PTL-List" (Problem-Part-List) in June and
adjusted the list into the Pagodentreff-Forum and in the MBCCCI-Forum
Mercedes-Classic-Car-Club-International GmbH).
It’s nice to see, that you recognized the Spare-Part-problem too.
Same cars = resembles problems.
It gives even more W113 Spare-Parts, which are no longer available.
Other Spare-Parts are from worse and very bad quality. Repairs at
Engine, Automatic-Transmission, Fuel-Injection-System are retarded
thereby and made impossible in individual cases.
Other Spare-Parts became very expensive in the last years. Their
price partly doubled in less than 5 years.
A Steering-Gear for over 4.300,00 Euro, an Automatic-Transmission
for over 5.300,00 Euro and a Brake-Drum for 1.300,00 Euro, per
piece (1994: 70,00 Euro)? Or Pressure-Control-Valves for the R11
(230SL) Injection-Pump no longer available? There are still many of
such examples.
The worst is, many of individual Pagoda spare-parts-customers get
arrogant or none answer from the MB-Classic-Center. Complaints of
individual customers are answered very often in such a way, as if it
is the problem of a particular. The MBIG Mercedes-Benz-Interest-
Community, one of Germanys oldest official Mercedes Mark-Clubs
gathered amazing experiences in many years here.
The consequence is: Many Pagoden drivers can hold their cars only
heavily or for no more drivingready.
Exactly that is the reason, why the list is so important for all of
us.
And some more: Nearly 10,000 Pagoden owners clicked the two Forum -
Threads in the meantime. Nevertheless the German Mercedes-Classic-
Center until today does, as if there would not be the W113 - PTL
list. Are we customers or fat booty?
Detlef Kupfer, Bad Homburg (Germany)
Stern-Garage
Post by: Longtooth on September 26, 2006, 02:04:22
Parts, and whether re-manufactured with original molds or materials or not, are a simple function of price supply/demand.  Whomever is in the supply chain has to make a profit at a reasonable level (read this to mean for a given investment of capital, what's the annual return on capital taken over some period of time compared to the return on some other use of that capital over the same period).
Same applies to time/effort devoted to supply/sales/distribution/inventory costs.
With the simple economic's in mind, consider now the demand side of things --- read quantity of parts one could reasonably be able to sell on an annualized basis.
Some stats on the various W113's...
230SL - 19,831 Produced
      - >50% produced in '65 & '66
      - 11,726 (59% of Total)Exported (outside Germany)
      - 4,752 (24% of Total) Exports to US
      - 2,166 7/1/90 still registered in Germany (Kraftfahrbundesamt)
        -- 8,105 (41%) Non-Exports Produced
        -- 27% of Non-Exports still registered in Germany in July '90
      - ~5,300 by inference (~27%) of total production still registered/used somwhere in the world... in 1990... ~25 years since Mean year of production ('65)
250SL - 5,196 Produced
      - 99% produced in '67
      - 3,808 (73% of Total) Exported (outside Germany)
      - 1,761 (34% of Total) Exports to US
      - 427 7/1/90 still registered in Germany (Kraftfahrbundesamt)
        -- 1,388 Non-Exports Produced
        -- 31% of Non-Exports still registered in Germany in July 1990
        -- ~1,550 by inference (30%) of total production still registered / used somewhere in the world... in 1990... ~23 years since Mean Year of Production.
280SL - 23,885 Produced
      - 37% produced in '70 & '71
      - 18,681 (78% of Total) Exported (outside Germany)
      - 12,927 (54% of Total) Exports to US
      - 2,590 7/1/90 still registered in Germany (Kraftfahrbundesamt)
        -- 5,204 Non-Exports Produced
        -- 50% of Non-Exports still registered in Germany in July 1990
        -- ~12,000 by inference (50%) of total production still registered / used somewhere in the world... in 1990... ~21 years since Mean Year of Production.
That's a total W113 production of 48,912 units.... mean year of production being ~1967.... 39 years ago.
There appears to be a significant drop in residual registered/used vehicles between 21 years since Mean Year of Production, and 25 years since Mean Year of production.
% of Total Production Inferred Registered / Years Since Mean Year of Production
     27% / 25
     31% / 23
     50% / 21
This is an exponential decay with time.  The forward projection to 40 years since Mean Year of production would predict <5% of total production still in use.
This is probably somewhat understated, since the projection is based on cars in use after 20 - 25 years since new, and as we all know, the cost of maintaining a car after 25 years vs costs of a new car becomes excessive, & reliability drops off at an increasing rate.  Add to this the effects of rust in all but the driest of clime's (Italy, Spain, Near East, South-Western US, Mexico, etc), and the rate of car's leaving the use market after 25 years would increase beyond the exponential predicted by the 20 - 25 years of use.
As an example, say 5% would miraculously still be in use or used as show cars, collector cars, restored or maintained daily drivers, or in some state of preparation for future restoration and use.
That would predict approx. 5% of 49k or ~2,500 remaining units in some state of use/repair/restoration/waiting for restoration.  Less than half those would be 230SL's... far fewer yet the 250SL's, and over half being the 280SL's.
Consider that the estimated total was <19k in mid 1990, or 39% of all W113's of which nearly 2/3's (25%) were 280SL's, 3% 250SL's, and 11% 230SL's.  If the exponential projection is used to project the percentages to the 40 year mark (since mean year of production), then the 230SL's would have 2.2% (of total production) remaining in use/restored/waiting to restore, the 250SL's having 3% of it's total production, and the 280SL's having 4% of their total production. If the relative proportions remained the same, then at the 40 year mark the 5,000 projected units still in use/restoring/waiting for restoring would translate to roughly 1.5k 280SL's, <250 250SL's, and ~750 230SL's.
So... from a business / economic's point of view, the business of providing classic car parts which are unique to the W113's has to be a very low volume business indeed... and with such low volumes, and decreasing volumes with time, the unit prices have to become very high in any event.... and the higher these prices have to become, the fewer of the W113's will remain in the restorable / restored catagory... accelerating the rate at which the vehicles in the non-restored catagory already will become parts cars.
The only parts that will remain at some reasonable level are those that aren't unique to the W113's... but were also used on the 111's, 108's, etc. of the time.
So... while we may try to get the Classic Car Center to contract to produce more of the rare parts, or even produce any of them, the MB Classic Center is anything but a philanthropic organization.... and must 1st and formost make a competitive roi on whatever capital it has to invest.... just to contract to have any parts produced.  This will inevitably diminish with time, so that more marginal uses of capital by non-MB restoration parts business's will spring up over time... quality being more / less also marginal, or less than authentic.  There will also be fewer parts producers, as the reduction in volume/demand will force consolidation of whatever parts producer's still exist.
I've also discovered a phenomena recently... a few years ago, new MB beauty rings (230SL's thru 250SL's) were in the $75-$100/unit range (I still have the quote from 5 years ago).  In the meantime, they had become unavailable from MB or anybody else... and prices climbed to over US$250 per beauty ring if you could find them.  It actually become roughly break-even with having the old ones you could find restored by a premium chrome house.... not just rechroming, but taking out dents, deep scuffs and scratches as well.  I recently resigned myself to looking into both options... finding 3 or 4 that were in better shape than mine at some price, or having mine restored.  So I inquired with my MB parts source as to the now going rate I'd have to pay for nearly pristine ones --- rechroming perhaps the only extra I'd have to put out myself.... but dent/gouge/scratch free.  Lo & behold, MB had them available again though... but at retail $200 ish now... 5 years later over double the price.... albeit competetively with the costs of restoring the existing ones.
Now, in the ensuing 5 years the supply dropped, and the demand accumulated until it was economically worth a competitive roi for MB to invest in another run of these... and I'd guess a reasonably low run number... so that the next time the same parts will be roughly double the price once again... 5 more years hence.... with fewer in the next run than in this one.
Just think like a business does... how to maximize your return on capital... and you'll get the picture on what parts will be produced... how long between run intervals while demand accumulates, and the alternative method of obtaining the parts (machining them to original tolerances?... new castings?  new metal bending molds? while MB Classic Car controls it's parts to maximize profit, while still providing enough, often enough to keep the demand rising (so that more of the car's don't end up more readily available as parts cars which decreases the future volume of demand by an even greater rate.
Consider that if MB Classic Center weren't contracting to produce any spare parts at all how many of the W113's would still be on the road or being restored...  the price for restoring one at all.
Basically, providing a wish list has to be weighed against the profit MB Classic Center needs to use their capital to satisfy the wish(es).  It's a business, after all, isn't it?... and last I heard MB wasn't in the habit of marginalizing their roi on use of capital.
And, for the record, my statistic's on model production volumes, exports, etc. are from Engelin's book Vom Barok zur Pagode.  The exponential fit of decay of units available has a 90% correlation coeficient (Rsqr for those with stat background) , so there's a definite exponential decay, though the uncertainties are relatively large with only 3 point from which regression is done.
I won't vouch for the accuracy of the projections to the 40 year since Mean year of production, nor the world-wide inferred numbers (inferred from the German Vehicle Registration office in 1990 (also from Engelin's book))... the 5% number seems somewhat realistic... but even if it's 10% the entire remaining portion of the economic's still applies in spades.
The more the W113's are used, driven, the more will bite the dust and become parts cars at best. We all know this inherently, can bank on it absolutely... the only question being at what rate it occurs.
Longtooth
'02 SL500 Sport
Post by: vincesy on September 26, 2006, 14:53:05
Longtooth,
Your numbers argument is definitely very convincing and is probably the major driving factor behind the parts. However, a business person might look at your numbers differently.
1.  As the cars get older, their need for parts becomes greater.  While there are smaller numbers out there, on a per car basis, wouldn't the pagoda be a more profitable candidate for car part manufacturers?  There is money to be made for the few specialized suppliers that emerge from consolidation and the niche market players.  In the end it's still a matter of supply and demand.  If the supply dries up too quickly though, then the same demand though small will have become relatively big and attractive enough for some businesses.  The threshold of risk and profitability also differs greatly for MB and the aftermarket firms.
2.  The projection to 40 years after mean production year seems too aggressive.  I'm more optimistic and think we're close to a level that will not fall much lower from the current numbers.  There will still be some fallout as some pagodas deteriorate to a point beyond financially justifiable restorations or maintenance but I expect a higher percentage of the remaining pagodas to survive in the coming years.  I think Darwinism is at work here and most of the weak cars (or owners) have been screened out already.
3.  Desirability should be taken into account on top of the numbers.   I expect a lot of the sedans or less popular cars of the same age to suffer a steeper decline in numbers than the 113s.  Hopefully it'll be these cars that would benefit from shared parts with the w113 and not the other way around.
While there may be more of these cars out there, the motivation to restore or maintain most of them (except the w108/109 coupe/cabriolet) is probably not as high as for a 113 and therefore makes a less compelling story for part manufacturers.
4.  The goal of MB Classic might not be entirely profit oriented.  When MB announced it would support any production car that's over 20 years old (their definition of a "classic"), I believe it was partly in pursuit of certain intangible benefits.   There is advertising value and prestige attached to seeing MB cars still running after many years on the road.  It is the same philosophy behind their High Mileage awards, the birth certificate program etc.  Supporting  their classic cars is a good way to promote MB's legacy and foster loyalty amongst current customers which can translate into business with newer MB models.
Vincent
Post by: Longtooth on September 27, 2006, 23:58:33
Vince,
I can't / won't disagree with your arguments, and for the most part, I think we're in good agreement.
Your Point #1:
Price has an inverse relation to demand volume.... AND use of Capital for ROI seeks the greatest ROI at lowest possible risk.  My statement is that MB Classic selectively manages supply... therefore price.... therefore ROI.  They can do this because authentic restoration seek's authentic MB parts... and MB Classic either still owns the capital used to mfg'er some of the parts, or have contracts that require their vendors who now own or lease the capital equipment to sell exclusively to MB for resale thru MB "official" channels.  When an independant supplier seeks to enter the market as the price makes it economically practical, the supply can then increase... relative to demand and price drops ... and guess who goes out of business first?.. in other words, for a low volume business, if you don't "own" the supply, you have to take a loss until you drive the competetor's out of business by pricing below the economically valid level.  My point was and continues only to be that requesting MB Classic to produce or make a run of some of the rarer parts for the W113's won't be done because of MB's philanthropy, but only when it makes competitive use in capital in terms of ROI compared to some other use of the same capital at that time.
My observation of the beauty-rings (230SLl/250SL variety) availability and pricing is just one example of a specific case of the point.  Retail MB part 4 years ago was $100 - $125... now, same MB part retail's at near twice that... and for part of that interval in time, there were none available from MB... or anybody else for that matter, unless they were used parts in less than "new" condition.
Inflationary pressures didn't drive the price to nearly double in 4 years, so the price increase had to be due to pent up demand created by withholding new MB parts for some of the intervale over the past 4 years.  As the demand increased without a supply, the alternative was to restore what already existed... which forces high labor rates for removing creases, dents, heavy abraision (curbs), not to mention rechroming... which get's the restoration costs into the $200 range/unit, for the ones that are even restorable.
At which point, MB Classic can decide to make another run... and instead of the restorers or some other metal bender getting into the business and taking the profit, MB can do so with an even greater profit margin... increasing their ROI to continue to supply a few more parts (until the pent-up demand eats up their new supply)... then the cycle starts over again.  When the rate of increase of pent-up demand reaches a specific threshold that makes the potential time return on capital less than it needs to be (competitive use of capial at play), MB has no incentive to supply any more parts.... so in time, the Classic center just stops making them available at all.
Yes, there's a marketing value to maintaining a few cars on the road and in show-rooms, but only if the prices for them continues to appreciate, since, if they don't, the 'cieling' price is reached and it doesn't become economically advantageous for anybody to continue to restore them, or even maintain them to the same level.
I'd bet that MB Classic has this down to an economic science since they've been doing classic parts for their 'classic cars' probably longer than any other manufacturer.  Prices for replacement and spare parts will go up at greater than the rate of inflation... commensurate with the alternative price for restoring existing parts, and only if and when the time value of use of the capital required is economically justified... meaning that if the rate of demand isn't high enough (pent-up or otherwise), they can't afford to sit on invested capital tied up in inventory that takes too long to depleat.
This in turn has to be balanced with other parts suppliers willing to take lower return on roi to capture some of the available market.  I'd bet, however, the demand and rate of demand for parts is a very well kept MB secret, so that those willing to take lower roi than MB on use of capital have to somehow estimate the demand rate.. which increases their risk on use of capital.... and when that's considered in their economic equation it reduces the amount of capital that will be used at that level of risk for restoration parts.
By the way... giving out plastic molded awards for longevity of vehicle use (miles driven) is pure MB hype.  They get the publicity and marketing value for the cost of a few press releases and a mold for a piece of plastic.  I'm definitely not impressed... more adversly impressed... MB's "prestigeous" awards now reduced to a piece of plastic???  Cheapen's MB's image, IMO... and in any event certainly cheapened my image of their business.  Of course this is part of the maintenance of "demand" excercise, but it certainly isn't worth that much (to their "demand" maintenance equation) if the awards are plastic molded parts, now is it?
As far as the projected remaining W113's go at 40 years since Mean Year of Production, it's anybody's best guess as to what the real numbers and rates of decay are.... mine's simply based on the most rudimentary of methods... analytically founded.  Like I said, even if you double my projections, nothing changes in the conclusions.
I just think it's naive to assume that getting a list of requested spare parts together from as many W113 groups as exist will result in any increase in spare parts availability from MB Classic.... as if MB CClassic economics and business executives don't already know the ddemand better than could probably ever be put together by an ad-hoc method of owners.
On the other hand, there's nothing to lose by trying is there?  ... who knows?... maybe my assessment of MB Classic and economically competitive use of capital's all wrong.  I'm not so sure the price/profit point won't materialize .... but the prices that emerge would kill off most who harbor a belief that they'ed 'buy' that spare part if it were available.  Don't we keep reading on this site about "it's not worth $nnn" for the interest of those seeking those parts?  The most recent example was a 280SL oil cooler... $900 from MB Classic... and those were used on more than just the 280SL.... so a bypass is the alternative... or finding a used one that won't bust either is the other.  What-do-ya wanna bet that a used on is in the $500+ range... and that's with pot-luck on whether it holds together or not.... lotta money for a risky buy, no?  Is it any wonder, then that MB Classic's charging $900 for a new one?
There should be no doubt at all that the rarer the demand for a part, the dearer the price for it if it's even available at all.
It's not about keeping a car running... just look at some of the '30's and '40's cars still running and being used in Cuba, for example... bailing wire and a welding torch will hold them together and keep-em running, more/less... it's about maintaining a classic in reasonably good appearance & reliable running order (or showing them).
Which reminds me... when do you think we'll see some late mode MB 6's, drive-trains (modern tranny's & rear-ends), & modified suspension system's, fatter, larger diam. wheel's & tires shoehorned into some of the classic's... W113's included?.  It'll happen you know... when it costs as much to do that as it does to restore & maintain to original condition.  When it does, it'll start taking an increasing share of the authentic crop of available drivers and restorable versions off that list.... reducing the demand for spare parts for the authentic's at an ever faster rate.... and no telling what'll do to the demand for the authentics still in use... could force the ones that are't fully restored pristine condition ones into the dust.. since their only practical value would end up being modified to satisfy the suped up modernized versions... body shape being more/less the only left-over part that's still from external appearances (only) a W113.
Longtooth
'02 SL500 Sport
Post by: Longtooth on September 28, 2006, 01:03:24
Vincent... here's a place where we disagee..
"I think Darwinism is at work here and most of the weak cars (or owners) have been screened out already."
I think the screening out process is a function of demographics of disposable income, relative to cost of maintenance/restoration.  I think the demographics continues in the same direction, and at an increasing rate as it has been... i.e. lower and lower proportion of population with a given level of disposable income as time as moved from the 70's to now.  More and more 2 income earning families to make ends meet or maintain reasonable middle-class status.... as a proportion of the population... this is true in Europe, US, and everywhere else.  A process that's been going on since '70's and continues unabated is a greater and greater separation between the rich and poor... with more and more proportion falling into the lower catagory relative to the higher one.... a reduction in middle class proportion.
If the proportion of population with disposable income at some threshold level is decreasing, while the prices/costs of maintenance and restoration is increasing with decreasing volume, then the relative cost of maintaining and/or restoring a classic is increasing by more than is apparent in prices alone.
In other words, there will be less and less disposable income spent on maintenance and restoration of a classic W113... or any other classic for that matter.  The disposable income that is available for this pursuit will come from a smaller and smaller segment of demographics, spent on fewer and fewer units. ... meaning prices of restoration and maintenance increases as fewer and fewer are able to afford to continue to maintain and / or restore a classic.
I think that's inevitable... the question only being in my mind at what rate this occurs.
At the moment, we're seeing the effects of the baby-boomer generation reaching their peak income producing years and peak disposable income years.... their offspring reaching the years of being out of the house, for example, ability to downsize housing for another.
Technically, I'm just ahead of the baby-boomers... one could consider me on the earliest tail of it I suppose.  So as I go, so come the baby-boomer's behind me...
So, for the next few years we should be seeing an increase in demand for classic car's ... though I'm not sure they won't opt for the cars of the 70's (as 'classics') more than those of the 60's... nostalgia of their early teen and teen years being a large driver of what car's become desireable with disposable income.
In fact, historically, the 'classic's have seen demand increases during the period where the disposable income set (say beginning in their early to mid 50's) have seen their teen years.... which is roughly 30-35 years prior.  So by the time my brother (middle of baby-boomer generation) reaches his early 50's in the 2010-2015 time-frame, the nostaligia cars of 30-35 years prior should come from the  early to mid 1980's.
This stands to reason, I think, considering my brother's 14 years behind me... so if I saw the W113's as the car to own in the mid-60's, then he (his generation) should see cars produced ~15 years later as those to own ---- '65 + 15 = '80.
Of course, off-hand, I can't think of an '80's car I'd like to own and/or restore... but I'm sure the generation of by brother can.
Of course this is pure conjecture on my part... but if it's even somewhat true, then the disposable income set in 5-10 years will be proportionately spent on cars of the 80's.... less on cars of the 60's... so conceivably demand for the '60's classics will drop by more than it's dropped already.  The demand that does materialize will most likely be for the '60's W113's that are already in good shape... or restored to a reasonably good level already... and those will thereofore carry a more premium price.... the other's should drop in demand... therefore price won't continue to appreciate as much or will remain stable.... i.e. stay even with inflation.
Anyway, that's my premis.  Unless there's some new hype that develops & sweeps the US or some other major high disposable income county for the W113's, there'll be a split in pricing... those that are near authentic and can be restored to authentic at a reasonable cost will appreciate at an increasing rate, and the rest will start to dissappear from the market--- parts cars, seriously modifieds, and rust bucket scrap metal salvage value.
The "seriously modifieds" --- modern power plants, drive trains, suspensions, probably some body mod's to go with them, could and I'd guess will take the lion's share of those that aren't capable of restoration, so it's not like you won't see the W113's body style around... but under the hood and probably the interior's won't be recognizable as being either from MB or the '60's.
Longtooth
'02 SL500 Sport
Post by: rob walker on October 11, 2006, 09:51:28
Centre exhaust heat shield, any ideas on where one of these can be obtained SLS can no longer supply, nor MB dealers in UK. Its a bit of bent aluminium, would have thought some manufacturer would be producing.
Rob Walker
2004 230 SLK silver
Post by: Joe on October 11, 2006, 10:16:53
While you make some persuasive arguments, Longtooth, I have difficulty in agreeing with all of them. The Pagoda is simply a beautiful car and will always be desired for that reason. Whether it was popular in a particular stage of one's life is, I think, of no consequence.
We see more and more 113s being restored and I can't imagine an equal number being run into the ground, the way they were twenty years ago. Comparing them to 300SLs would be valid, I think, in terms of projecting their future, and you certainly don't see examples of that car sitting out in the field under a tree, rotting their way back to their origins.
Just my opinions.
Joe
Post by: Benz Dr. on October 11, 2006, 13:33:22
First thing you need to figure out is the whole
 '' classic car '' thing and then get back to us.
 Anyone who knows anything about cars knows 113's are milestone cars, antique cars, maybe historic cars or vintage cars, but sure as hell NOT classic cars.
Post by: rob walker on January 22, 2007, 01:10:31
Not believing I am the only one seeking a centre exhaust heat shield which I have been trying to locate for almost 1 year, just been told by SLS in Germany that they have managed to get a supply of these rare parts, and now have them in stock.
Rob Walker
Spain and Turkey
Post by: Chad on December 09, 2007, 18:47:22
Having started the topic of NLA parts/ rare parts slightly over two years ago, I opened it up to quickly peruse it again as I am thinking along the lines of availability for the original rubber/vinyl mats for the 230 cars.  I remember it was interesting but then the thread got unfocused venturing into consideration of economics and market forces and even the official definition of classic automobiles.  These are peripherally related to the NLA issue, I suppose, but refocusing/revisiting the NLA topic I believe is useful and important (and done often in various questions on the forum).
(1) Any more focused discussion of NLA parts?  Has anyone found availability of a part they thought was v. rare or NLA?  Has anyone discovered a need for a part they believe is either rare or NLA and quite possibly is not and want to add the part to the list of wanted/needed in general for the maintenance of these cars? Anything to pen to the earlier list?
(Rob Walker's comment below from 22/1/07 relating to center exhaust heat shield availability is quite exactly the useful information that may help someone who is scratching their heard over a part.)
(2) I remember writing several letters to the Classic Center regarding a list of parts over a year ago, initially to see if this is the case, but never heard back and therefore could not form the grounds for a further discussion with them. Has anyone else thought of a means to achieve the ends of obtaining rare parts, some other venue or avenue for discourse?
(3) IMO it is in our best interest to keep these vintage automobiles in original condition as much as possible.  This is only reasonably possible if the parts are there.  I fear that escalating prices of parts and unavailability will tempt many owners out there who are non-forum members to deconstruct and hotrod the cars.
This posting is already well beyond 100 words which is the limit of what I normally can sit and type or might sit and read at one time. In any case, may this topic possibly be resurrected occasionally and, more often than not, on point.
1967 230SL
Post by: hauser on December 11, 2007, 02:53:15
I guess we can add the ashtray along with passenger side mirrors.  At least for now!
Post by: mbzse on December 11, 2007, 06:19:36
Having started the topic of NLA parts/ rare parts .../...
An answer to you must have been lost within M-B Classic organisation..? Because, the German Club Pagode and other enthusiasts have since way back compiled a List and there is an ongoing discussion and update of this NLA List of W113 parts with the Classic Center.
See Alfreds and Detlef's previous postings in this thread (below).
Download the list of problematic parts at:
http://www.pagodentreff.de/diskussionsforum/t2915-w113-pagode-problemteile-liste-14.html
latest version from June 2007 can be obtained there in .pdf; see Posting #133
/Hans in Sweden
Post by: Mike Hughes on December 11, 2007, 17:12:43
How about the "short fuse?"
Post by: Bob G ✝︎ on December 11, 2007, 19:53:34
question I was  able to locate  a right hand door mirror for my car new on ebay in Germany for I will not say that would put me in the insane asilum. however this  guy said he just got 12 more in. How come the classic center cannot get them. By the way here are some parts I am looking for.
1) center exhaust shield
2) 1109100018 trim plate for seat reclining knobs
3) dash light rectifier for brightness
4) knobs for back carpeted boards
6) dam near another parts cars I go broke buying parts for this car.
Its a faris buler thing I just walk around and dust it off, Am I crazy?
Post by: Bob G MN on December 12, 2007, 09:43:50
Mike,
I recently got the short fuse from Millers.  you need to call them and be sure they know what you want or they may send the wrong one.
Post by: Mike Hughes on December 12, 2007, 15:55:05
Good to know.  The M-B dealer across the street says they are NLA.
Post by: JPMOSE on January 10, 2008, 16:41:29
According to the dealer, the Chrome Cowl Vent Cover is no longer available (even in Germany).
Checking many sources (such as Millers), I came up dry.  But then I lucked out! Bud's Benz had one left so drove out to Douglasville and picked it up today (mine has a small piece broken off so rechroming wasn't an option).  It's amazing how precious it seems knowing it's the last one.    Hopefully, DB will re-manufacture it soon.
Best Regards,
J. P. Mose
1968 250SL
1987 560SL
Post by: Bob G ✝︎ on January 12, 2008, 17:35:45
Center trim plates for black curled recliner knob for back rest. MBZ # 110 190 0018 NLA
If anyone has an extra set that is nice I am looking for them.
Post by: JamesL on March 29, 2008, 12:34:44
http://www.service-and-parts.net/dcagportal/DCAGPortal/register.action
Is this of any use?
I have not registered...
Post by: awolff280sl on August 08, 2008, 10:00:40
Driveshaft centering cross
Hexagonal Flex-disk
Post by: scoot on August 08, 2008, 13:54:34
For me some of the most annoying NLA parts are little items, such as:
1.  Correct sun visor clips for an early 113
2.  Correct vertical-handle fresh air vent handles for an early 113
3.  Correct seat back tilt release black plastic handle for a 113
On all of these, MB will gladly substitute the incorrect part (which won't even function in the case of the visor clips).
Post by: awolff280sl on August 08, 2008, 14:39:18
MB may be substituting parts without checking all the applications.
In the case of the flex-disc, when I went to install the round one that substitutes for the hexagonal one, the tranny flange bolts hit the rear tranny cover! I was lucky to then find a hexagonal one, but they are becoming more and more rare.
Post by: Benz Dr. on August 08, 2008, 14:45:09
On some flex disc aplications you need to use two washers on the bolts that are long enough to hit the rear tans cover. This is standard practice on a 190SL.
Post by: awolff280sl on August 08, 2008, 15:19:23
Thanks Dan. While I considered using more washers, I just wasn't comfortable with having to do this to use the round flex-disk.
Post by: scoot on August 08, 2008, 16:52:09
...which I find to be totally unacceptable...
Post by: Lilly on August 17, 2008, 00:19:10
I'd like the list to include all-red tail-light lens assemblies.  I've tired of replacing the useful transparent red "lens tape" covering a small hole in my lens.  Recently, I thought of searching for a red bulb to use instead of the clear (white) bulbs used for the tail light having recalled seeing orange, blue, red, and even purple lights sold in parts stores for modern cars...I'd sense a blessing if I found one with the same bulb base so it'd twist and lock into the socket though. :evil:
Post by: hauser on August 17, 2008, 00:45:12
Lilly, the all red lenses are available.  They are reproductions and I believe that this is why MB no longer makes them.  You can get them from Gernold at sltech.
Post by: Jonny B on September 03, 2008, 16:48:38
MB has asked Will Samples for a list of NLA items. He has posted this through the Gullwing group and several other groups and individuals on his roster. I went through the list and condensed the items and havce sent this to him.
Keep on posting, but this went out on 3 Sept 08.
Post by: Benz Dr. on September 03, 2008, 19:16:19
I got some info from Will this morning and I told him we were looking at the same things. So maybe MB is looking at this after all but producing some parts won't happen because the low numbers won't add up. Things like lighting and other things that are needed to keep the car runing safely shouldn't cause you to quit driving your car.
Post by: Ziggy on February 25, 2009, 17:58:51
Part number 1138300119 is no longer available ("defroster nozzle left") does anyone know if there is a replacement of some sort?
Post by: waqas on February 25, 2009, 18:34:04
These are very hard to find used. But they usually never go bad. They're made of some kind of hard cardboard, and the two halves are stapled together. The driver-side nozzle is a royal PITA to remove (wiper linkage needs to be completely removed). I suppose they can get damaged during removal and installation.
Have you checked with Bud's or Miller's for a used part? Dan (Benz Dr.) has a parts car-- perhaps you can check with him?
Post by: Mike Hughes on February 25, 2009, 20:19:08
OK, here is an obscure part that many of us could use:  116 693 00 14
This is a clip that is used to secure the top of the cardboard pieces on each side of the trunk to prevent them from hanging loose and potentially tearing.  Two are required, one for each side.
Post by: hill on February 26, 2009, 01:09:52
Unless some one knows of a supply I was unable to buy an ignition switch for early 250.
Post by: 66andBlue on February 26, 2009, 05:51:33
..  This is a clip that is used to secure the top of the cardboard pieces on each side of the trunk ..
Hi Mike,
this is interesting. I was not aware that the cardboards in a 230SL where attached. I thought that they are held in place just by pushing them behind the lips in the bottom and behind the rails for the weatherstripping on top.  Although it sure would be nice to have some clips that fix this boards in place. How is it on a 280SL?
If the 116 part is NLA, perhaps the next generation might work, for example, a 126 693 0014?
Post by: Mike Hughes on February 26, 2009, 15:40:10
You have described better than I could how the top of the cardboards fit behind the trunk lip channel.  The clip attaches to the edge of the channel and holds the edge of the cardboard in place so that it does not drop down and out from behind the channel.  I have tried ordering these clips from my usually very competent local M-B parts guy.  The part# is a good # and only costs a dollar or two but each time he places an order a quantity of them shows up as being in Germany but then the shipment is backordered and then is purged out of the ordering system after a time.
Post by: Joe on March 01, 2009, 17:01:27
I don't think anyone has mentioned the chrome ring around the ignition switch. This looks like it would be an easy part to make, if one were in the business of stamping out similar parts.
Joe
Post by: J. Huber on March 01, 2009, 17:38:38
Just a thought. Would it be more effiecient to have a running list of the NLAs, so we easily determine if its already been mentioned? Maybe it could be a wiki thing? Or do we have that somewhere and I am missing it?
Post by: Peter van Es on March 01, 2009, 21:05:39
James,
you are right, that would be much easier in a table in a Wiki. Editable and maintainable by everyone. Please feel free to start one.
Regrettably most of us are happy to post here, but reticent to update the wiki.
Post by: JPMOSE on August 19, 2010, 18:54:51
I just read through this list again after a year or so.  While it gets frustrating not have all the parts we want for our babies.....TRY OWNING A W111!   I recently purchased a 280SE 3.5 Cabrio that's in #2 condition.   As with all cars, there are parts needed to make it the way "we" personally want them.   The list of unavailable parts is numerous compared to Pagodas.   I have been fortunate to find a lot of them....but the prices!!!   Also, there is a world of information on this site for Pagoda owners....nothing like this exist for W111s (at least in English).
So be thankful for your Pagoda....but get your parts before the supply dries up!
Post by: 114015 on August 30, 2010, 19:35:08
Well yes, ...
Personally I am extremely interested to know what is no longer available and what is probably going to be reproduced (by daimler ag or others) again.
I have some (unsorted) kind of lists about unavailable or problem parts ("does not fit", "way too  expensive") but I have to work that up first.
I will then post it here - would love to do that (if I may) in the Wiki section.
But still takes a little while - I am currently a bit more busy with other things...
(parts collector)
Post by: JPMOSE on February 29, 2012, 23:34:34
This is a very useful posting.  I am just getting back into my Pagoda after a two year break.   I know parts on my W111 are become NLA at fast rate.   Does anyone have some updates for this?
