W113 Pagoda SL Group => General Discussion => Topic started by: Longtooth on September 01, 2006, 04:58:40
Title: 250SL's Differences
Post by: Longtooth on September 01, 2006, 04:58:40
I was brousing thru some other 250SL's pics today on OurSL site and noticed for the 1st time that many of them have a ton of features I thought were only introduced with the 280SL.
Among the most obvious:
1. dual brake fluid safety switches (at brake fluid reservior)
2. black, non-chromed inside rear view mirror in several,
3. front and rear side reflectors in several
4. door panel elastic flex 'bags' instead of the fixed inflexible type.... shock! in more than one.
5. 280 type horn rings in several.
6. bumper guards in more than one (shock!).
7. no passenger side visor mirror on more than one.
Now, some of these might be there due to replacements of parts by unknowing persons or done without consideration for maintaining the originality intact.... but since all of the above were shown on more than one 250SL I get the impression that these features were being introduced on later 250SL's as they became available for pre-production versions or inventory availability in advance of the introduction of the 280SL.
I mean if you took the 250SL plate off the trunk lid nobody could even tell it wasn't a 280SL (if the beauty rings and hubcaps were replaced with the 280SL single piece version) without reading the VIN.
Mine's a mid-August '67 production date version and has none of the above listed 280SL features.... though it does have the 280SL type wiper blade carriers.... which I'll get reversed one of these days.
Does anybody know whether some of all of the above listed features that are distinctly known or believed to be exclusive to the 280SL were being introduced during the later (or earlier?) production run of the 250SL?  Is there even a source for knowing absolutely when each of the above began to be introduced prior to the 280SL's availability?
Longtooth
'02 SL500 Sport
Title: Re: 250SL's Differences
Post by: Jonny B on September 01, 2006, 05:27:55
Their was a BIG list of change in the 250SL at VIN 113-042-XX-XXX2980. At that point (check in Meredith's or Engelen's book for the full list)(and to double check the VIN for the change)is where the changes went into effect. Most of these are what you describe, different steering wheel, side reflectors (lights came a bit later), different heater levers, different door pockets, the change in the rear view mirror etc. etc. These were made to fit in with US safety requirements.
Engelen's book is the most complete, but it is only in German, and is available through the Classic Center (at least that is where I got my copy), Meredith's book does a reasonable job describing them. I think there is also a posting of the list compiled by Frank Mallory, and should be somewhere on the site. Check the search feature on that one.
BTW, mine is an early one too, and I am glad to have it that way. I like the early style features.
Post by: JPMOSE on September 01, 2006, 05:43:28
Mine is a '68 S/N XXX3011, built in July '67 and it does have all the named features except bumper guards (I believe this was an option anyway).
Best Regards,
J. P. Mose
1968 250SL
1987 560SL
Post by: Chad on September 01, 2006, 06:30:02
As Johnny B has pointed out. There was a clear point in the run where the major changes were made, with some smaller changes happenning at various small other points. This is widely known. The books describe it well. There are two flavors of 250SL, for sure, that line up with the general differences between 230 snd 280 cars. It is a matter or personal preference. For me, the most glaring change was losing the molded chrome inside door unlocking mechanism for the rectangular paddle-pull of the later cars. Little things like that change so much.
1967 230SL (Manual, rustless driver)
Post by: Bob G ✝︎ on September 01, 2006, 13:25:46
Some of the feathers on the later production 250SL are pre 280SL. what is funny is an early cataloge 1968 Mercedes-Benz automobiles shows a red 280SL and in the forkground is the mitty 300SLR. In the pictures that were used of this red 280SL are early wheel  trim cover and small hub cap, lower rear license plate trim molding and early small round knobs from the early style 230SL & 250SL. So you cannot always go by the cataloge pictures. Production changes very well could happen the next day on the production line as soon as vendor or new safty laws are passed on to management.
I do wish the big book from Germany on the 190SL /280SL would be printed in English. records seem to be losted on production of many of these cars in the peroid they were built and substituted later production parts have replaced many of the orginal vendor parts.
I would gladely love to see the list of vendors used during the production years of the W113 SL.
Post by: Vince Canepa on September 02, 2006, 06:40:15
One thing to keep in mind about catalog/brochure photos - the photos generally come from an archive of images, not by pulling a car off the production line and photographing it.  Thus, they can vary quite a bit from the car as delivered to a customer.  I have 230 and 250 brochures and they use the same photograph with the color changed (rather poorly in fact).  In one photo of the air vent on the dash, the photo is upside down.
Vince Canepa
113.043-10-001543
568H Signal Red
116 Caviar MB-Tex
Post by: Naj ✝︎ on September 02, 2006, 08:42:40
In my view, a 250 SL before Chassis # 2979 is a 230 SL with rear discs and 129 Engine.
After Chassis 2980, its a 280 SL with a 129 engine.  ;)
Post by: 114015 on September 04, 2006, 11:48:28
Hello Longtooth,
Because your VIN indicates your 250 SL beaing an early style, yours must look like a 230 SL, none of the below mentioned features should be found on your car.
I am aware of only one (!) difference between late style 250 SLs (i.e. model year 1968) and early 280 SLs (which had 2 piece hubcaps and red taillights as well), and this is the carpet.
250ies had always square weave carpet und 280ies Tufting (multi loop) ... if the cars are being kept original.
(Magdeburg, Germany)
Post by: Jeff Collins on September 05, 2006, 07:47:54
I have vin XXX2999,I think it was made in July but must have been later,it has the pocket door storage,etc.I am doing an unrestored/restored because it only has 73k on it.It really doesnt need a lot but I would like for it to look almost new again.
68 250 sl auto/ac
86 944 Porsche
96 K35 t/d 4w
99 ultramax
2000 fatboy pro
Post by: Longtooth on September 08, 2006, 03:37:25
The transition 250SL was apparently a mix of 230SL cosmetics some mechanics, and the 280SL cosmetics / mechanics.... differing features with time of production... and probably decisions to use intermittant supplies of incoming parts as parts used on earlier versions on some later versions.
Naj's take is an interesting one though...
The 280SL's 129 increase in displacment came hand-in-hand directly along with the US's laws for smog (emissions) reduction laws beginning with the '68 model years.  Sometime in '66 however, MB had already completed design of the major changes to the 230SL and had begun proto-production, testing, including the increased displacement to the 2.5L engine.  Therefore the design changes process began no later than sometime in '65, and decisions to make the design changes probably by early '65.
This timeline from the introduction of the 1st version pagoda (230SL) in '64 to decisions to make significant changes to it by early '65 for introduction 2 years hence in early '67, including the use of the 2.5L engine, including some cost reduction items is well within the normal MB modifications cycle and other mfg'ers cycles in that time-frame.
It can thus be argued that the 250SL was initially NOT concieved as an interim version, but that the advent of the new US emissions laws and the SL's US sales success with the 230SL and especially the automatic tranny forced the added displacement to the 2.8L engine to maintain the horse power and torque of the 2.5L with the inclusion of additional emmissions requirements necessary for import to US by '68.
The cosmetic changes incurred between the 230SL's later versions and the 280SL's versions shortly after the 280SL's introduction were nearly all based on cost reduction exercises in design... reductions in mfg'ing costs .... increasing profits.... and US DOT laws (side marker lights for example, bumper guards for another, increasing costs and decreasing profits for US version.
MB of North America had and still has a major stake in MB design and feature inclusions in new models... as of course does the US DOT and emmission's laws... California's being the driving factor since it's market is relatively large as the US market goes in general.  The '68 280SL wasn't even offered at CA dealers with a 4-speed tranny for example... a decision made by MB of North America.
I surmise therefore the many of the features found on and identified with the 280SL would have occurred more/less even if the emissions laws hadn't force the 2.8L engine and MB would have retained the 2.5L engine beyond '67.  However, given the new US emissions laws required for '68 model years cars sold in US, MB had to quickly adapt the 250SL to maintain the HP & Torque with the added emissions requirements... solution without a lot of yet to be discovered and invented technology was to simply compensate by increasing the displacement another notch (12%) compared to the 9% increase in displacement from the 230 to the 250SL.
The US market was also heavily into A/C and power steering as an option... in CA in particular, but I presume also in some of the eastern market's humid summer's areas.... and that sucked up more hp... another reason to increase the displacement to maintain operational accelerations.
So the 250SL ended up being morphed into a shorter than normal and expected/planned production run.  With the newly planned 2.8L version required to be available for '68 model year deliveries in the US, MB had to provide some other distinctive changes to the then 250SL's cosmetics... so the replacement features began to be changed in orders to suppliers as early as practical as the 280SL cosmetic changes (or safety changes required --- dual brake safety switches, for example) were designed and committed to the 280SL features design... no reason not to start that production as soon as could be implemented since the 250SL production could use them as soon as they became available... a good way to get production kinks & supplier yields taken care of as early as possible without an impact to production capacity at the MB factory.
A similar scenario took place in many other European cars where the US market was significant to production sales.... the e-type jag's so called series 1.5 changes were introduced with the '68 model year... and almost all the changes were in response to emissions and DOT safety items.
All the above regards MB's primary reasons to switch to the 2.8L 280SL from the 2.5L 250SL are my conjectures.
Longtooth
'02 SL500 Sport
Post by: Klaus on September 09, 2006, 09:15:29
Here is a rough translation of a few excerpts from Guenter Engelen's book "Mercedes-Benz 190SL-280SL, from the baroque to the pagoda". Engelen's book is based on his access to the company archives and interviews of the involved managers.
"The disadvantageous combustion chamber [of the 250SL] - being placed on the side - of the existing 6-cylinder engines resulted in pronounced cylinder distortions (out-of-round)...To compensate for this cylinder warpage the piston ring tension had to be high, which increased the friction within the engine....These problems led to early bearing failures and hairline cracks in the cylinder bore....Knowing these background facts explains why the 2.5 liter M129 was succeeded after a comparably short time by the 2.8 liter M130."
Klaus
1969 280 SL
Post by: Longtooth on September 09, 2006, 11:56:35
Klaus... coincidentally, I just received my copy of Engelen's book this morning in the mail.  From what I've glanced thru and read so far, the issue was related more to the market's desire for higher PS (Horsepower), competition (BMW), but I've got more reading to do later (when my wife get's off my back).
Longtooth
'02 SL500 Sport
Post by: Naj ✝︎ on September 09, 2006, 12:23:13
Anybody here had these problems  :?:  :o
Post by: Longtooth on September 11, 2006, 03:39:20
I've done some reading of Engelen's Vom Barock zur Pagoda today.
The thermal gradiants problem occurred the in-line 6 cylinder M127 (2.3L in the 230SL), and M129 (2.5L in the 250SL, & 250SE).  The 2.5L M129 was introduced first in '65 in the 250SE (W108), nearly 2 years earlier than in the 250SL.  The cylinder distortions are a direct result of thermal gradiants between the combustion chamber top portion of the cylinder and regions below it.... with higher rpm's causing greater gradiants and greater distortions.  The M127 & 129 suffered a far higher rate of cylinder wear and cracking than the other MB series engines at the time, and most of the effort in the motor division was centered on this problem for several years.  The M127 & M129 are nearly identical except for the 7 main bearings used in the M129 (2.5L) as opposed to 4 main bearings in the M127 (2.3L), and the 6 mm longer stroke used in the 2.5L M129.
The higher rpm's driven by owners of the SL series accentuated the problem because heat dissipation time from the cylinder walls was reduced under higher rpm's... therefore leading to greater distortions.  Among the earliest changes made to the M129 was the addition of the oil cooler... which marketing brochures called 'oil-water heat exchanger'..... to compensate for the higher running temperature in the longer stroke M129.  Among the other modifications to the M129 from before it's introduction were larger intake and exhaust valve openings... not just to compensate for the increased displacement, but also to reduce cylinder / piston temperatures.
The additional stroke length forces the rings to undergo greater stress at a given rpm relative to a shorter stroke since the combustion chamber temperature has to be dissipated in the same time (same rpm means pistons/rings travel further in the same time.... i.e. higher velocity and accelerations), leading to increased friction of rings on cylinder walls, and higher forces on the rings and walls, and
Since the combustion chamber size wasn't changed the volume of fuel/air in the chamber was the same as in the M127 (2.3L), hence the explosive force on ignition was the same in both.
Subsequent changes to reduce the stress's involved both reduction in gear ratio's (back to 3.69 from 3.92, and 3.92 from 4.08) which reduces the rpm at speed (one of the major factors in reductions in cylinder & piston temperatures), several increases to the ring clearance over time, and improved compression rings (chromed & tinned plated steel.
The US exported SL's were not nearly as prone to the higher cylinder wear & cylinder wall cracking problem because, as we all well know, the US speed limits reduced the probability of extended high speed driving....unlike the relatively low traffic and speed limitless Autobahn's, and the US market was more interested in low speed acceleration than high speed (due to the speed limits). Parenthetically, it was not at all uncommon in the 60's when I lived in Germany for the SL's and high displacement MB's and other sports cars at the time to travel half the length of Germany at well over 100 mph average driving speed on the autobahn... the only factor which reduced average elapsed time speed was that at those speeds 'Tanken' (stopping for gas) was necessary .... roughly 25 liters / 100km fuel consumption at those speeds...so an 80 liter tank went near empty about every 350 km (~220 miles or every 2 hrs or so).
Some factoids on production numbers and exports for the 3 SL versions (from Engelen's book):
The number of 230SL's exported to US was 4752... out of 19,741 total, and 11,726 exported in total... or ~25% of the total produced.
The number of 250SL's exported to US was 1761... out of total of 5196 produced, or ~33% of total production.
The number of 280SL's exported to the US was 12,927... out of a total of 23,885 produced... or just over ~50%.... the vast majority of the US exported 280SL's were automatic's.
The advantage of the 250SL over the 230SL and 280SL was that it retained the tight suspension of the 230SL for the most part, and it's styling cosmetics, while extending the horsepower slightly (actual hp of the 230SL was 143 despite the 150 hp in the literature... this according to documentation provided in Engelen's book), and a 10% increase in torque.
The actual shift to the 280SL was called for by competitive pressure and market demand for more "performance" which was deemed commensurate with hp in the mind of the 60's public.... remember our muscle car's?  In order to provide the 280SL M130 engine, however, the in-line 6 cylinder's had to eliminate the water jacket between each pair of cylinders... so that the bore could be increased to get the 2.8L displacement without redeveloping the the entire engine block and head.
Parenthetically, the increased bore on the 2.8L M130 increases the combustion chamber size, therefore would require higher fuel pressure and volume for the same combustion induced force on the piston.... therefore more hp all other things equal... so it isn't clear from Engelen's book why the M130 2.8L engine didn't suffer from the same cylinder distortions inherent in the pair cylinder M127 & M129 (2.3L and 2.5L) engines... so it's implied but not stated or discussed that it didn't suffer the same cylinder wear problem, and that the implied reason was the elimination of the water jacket between each pair of cylinders used in the M127 & 129 engine.  This wouldn't and doesn't explain, nor did the extensive other discussion in Engelen's book, the reason for the dominance of wearout occurring in cylinders 1 & 2.... rather, for example, than in the pair on the other end of the block... cylinders 5 & 6.
BTW, the cylinder wear problem occurred on 1.7% of the 2.3L M127 230SL after 2300 had been delivered (Chassis #2300 was produced in Feb '64)... so approx. within a year or so of introduction of the M127 (2.3L) engine to public consumption. Compared to 2.2L which was the same engine without injection and with a slightly smaller bore, which had nearly no failures for that cause (0.1% was the highest other failure rate for cylinder wear-out on the 220SEb (W111)... and 0.037% on the 220Sb).  This was reported in the book as being a major issue with the MB Executive Board, and several preventive measures were undertaken to mitigate the problem.... which resulted in the introduction in '65 of the W108 with the 2.5L engine.  It wasn't felt necessary to shift the 230SL to that engine at that time... since the export market for the W113 in the US was growing at an extremely high rate and it wasn't felt necessary to introduce the 2.5L engine in the SL at that time.  It is noted in the book that another Director reminded the board that it had been agreed at a board meeting already in July '64 to introduce the 2.5L engine in the SL at the International Auto Show in '65.
The historical context of the 2.5L and 250SL indicates that it was a marketing decision that let it lapse 2 years until '67, thru lack of having a competitive or revenue bearing reason to do so, and again a marketing decision to introduce the 2.8L 280SL in '68 thru having increased competition and the need to continue to grow the US export W113 market --- which it did going from 33% of total production with the 250SL to over 50% with the 280SL.
I've been spending some time looking at the extensive changes made by date and chassis numbers by model and model year, but my auto-parts German vocabulary isn't as good as the rest, so I'm forced to look up certain auto parts words --- for example, I couldn't for the life of me figure out what Cylinder "Verzug" was... I found it finally on the web in a Chinese-German dictionary... and asked for 'translation' .... google... and the chinese translated it into "distortion"... then the word "Verzug" made sense. My German/English English/German dictionary is ancient, and I've rarely needed it, but it doesn't contain all the automobile related terms so I have to look up the individual parts of some of the German words for some automobile parts to figure out what they are in English.
I'll report on some of the major changes between the 280SL and 250SL and when and what Chassis number they occurred on in another note in the next week. In the mean-time, many / most of the changes I listed in the first (top) note occurred on July 12' 67 beginning with 250SL Chassis number 2980.... all at once... for Safety related issues being driven in part by the US DOT rules.  BUT, the single "limosine" type wheel covers didn't occur on the 250SL... and wasn't on the 280SL until Chassis #45 built on Dec 8, '67.... while the last 250SL was produced in Nov '67.
Also, the side-lites weren't intdroduced on the initial 280SL production and was first introduced on the US export model in Jan '68 on Chassis #354.  It should be noted here, though, that Italien exports required by law a round (a-la Fiat's) a small round yellow reflector on the front fender... and this was required well before the introduction of the 280SL.... my parent's lived in Italy after moving from Germany (in '66? I think... they were living in Naples when I was married in '68 at least... and living in Germany when I left Germany in '64).
The orange tail-lights weren't introduced until the 280SL in Feb '69... a year after it's introduction on Chassis # 7938.... and then only in Germany, since in the US, the orange blinker on rear wasn't allowed by DOT until sometime later... I can't find this in the list of changes, but read it in the text somewhere else in the book.
Interestingly, new front and rear bumpers were installed on the 250SL and following 280SL beginning in late Nov. '67 with 250SL Chassis # 5041 (rear) and # 5092 (front).  The words used are "....einstellung", which could either mean a new "installation method", or "introduced", so I'm not sure which.  But... I wasn't aware of a different bumper style between earlier versions and the '68's and beyond... so I'm not sure what this actually means... perhaps bumper guards???? but the bumper guards weren't used in European models that I'm aware of.
Enough ... there's ton's of stuff about the W113's details in this book.  Somebody ought to get the rights to translate this book to English from the author and publisher.
Another little observation... one of the color pic spreads in the book for the 230SL shows the engine compartment...  and the expansion tank (coolant) is shaped like a large can.... thick pancake (round on top, cylindrical shape)... not the enlongated sphearoid I'm used to seeing.  Anybody ever see one of these coolant expansion tanks?
Longtooth
'02 SL500 Sport
Post by: Longtooth on September 11, 2006, 05:11:10
Naj, I need to make a correction to what you quoted from Klause's rough translation of Kegelen's book on the subject of excessive cylinder wear due to cylinder distortions.
You added a parenthetical part to Klause's rough translation that is highly misleading.
The actual translation doesn't refer to the distortions as being related to the 250SL's engine (M 129) at all, and in fact refers to all the 6 cylinder "in-line" engines of the time not the least of which was the M127 in the 230SL.... which Engelen refers to extensively and often in the period leading up to the 230SL and during it's entire production period.
My translation of Engelen's remarks are as follows... the remarks are provided in the 280SL section in discussion of what lead up to the reasons for why the 250SL's life was only 1 production year.
"The disadvantageous in-line combustion chambers of the existing 6 cylinder engines led to high "temperature gradiants" as the specialists referred to the biased cylinder distortions. High piston ring stresses were required to compensate for the cylinder distortion, which in turn degraded wear resistance of the engine.  This problem led to early bearing damage and hair-line cracks in the cylinder walls with the hard driven 2.5L and 2.8L engines of those years. Such a motor had only scrap value.  ...
But because new combustion chamber designs, a new head, and new more expensive production costs would be required, MB sat in the Klemmer [Ed. was between a rock and a hard place].  The new 6 cylinder engine wasn't available yet, while the market demanded improved performance.  And the competition -- at that time BMW aleady -- were bringing new, modern engines to market.  If one considers this back-ground, one understands why the 2.5L M129 had a relatively very short production run in the W113 and why the 2.8L M130 replaced it. .."
My comments ---- "the new 6 cylinder engine" not available yet refers to a new engine design... not the then existing MB 6 cylinder engines... the 2.8L M130 was another extension of the 2.2L that morphed into the 2.3L M127, then the 2.5L M129, and finally the 2.8L M130.
The cylinder distortion problem refered to above is elaborated in the section on the 230SL as "cylinder wear-out" related M127 2.3L engine.... I've commented more on that in my other note today... so the problem related to the then in-line 6's used in all 3 W113 series applied to them all... the 230SL, 250SL and not the least, 280SL.... it wasn't a problem specific to the 250SL! by any stretch of the imagnination, nor by anything written by or refered to by Engelen's book or text.
Longtooth
'02 SL500 Sport
Post by: Longtooth on September 11, 2006, 15:55:10
Some additional information on the cylinder wear problem on the 113's engines.... more specifically the actions that were taken to mitigate the problem somewhat on the 2.8L M130 engine in the 280SL.
In Engelen's book, Vom Barock zur Pagode, the section following the 280SL chapter is entitled "Das Grosse Fressen", which in this context loosely translates to "The big wear-out"... "Fressen" actually refers to animals feeding.. people "eat", animals "feed"... and is used as a derogatory term referring to 'poor eating manners' as in gluttenous or guzzeling.  In the context of the engine problem, "fressen" refers to the "eating away" of the cylinder walls... which in english we refer to as "cylinder wall gouging" or similar gross wear problems.
The subtitle of the chapter is (my translation) "(or: the old suffering of the rejuvinated ancient [ed. or old] one)"
This chapter discusses the cylinder wear problem as it relates to the 280SL and M130 engine.... and the steps that had to be taken to mitigate it... not solve it... simply to reduce the level of occurrance.
First, it was found that the cam used on the M130 in the sedan could reduce the cylinder wall temperature by 8C in cylinders 1 & 2 (where, in most cases the cylinder wear problem occurred), compared to the cam initially used in the 280SL's M130. Furthermore a reduction in compression by 10% would reduce the cylinder wall temperature by another 4C.... so that production M130's used in the 280SL used 9:1 compression ratio's on cylinders 1 & 2.  A further "stately" cylinder temperature reduction was achieved by reduction of the coolant temperature to 80C from 105C by using coolant with 50:50 mix of glycerin.
However, these conditions didn't solve the cylinder wear problem, they just moved the wear out further in time (use).
Another change that increased wear-out lifetime was a reduction in rpm... which was achieved on Nov. 27 '69 by changing the standard rear-end ratio to 3.62 from 3.92... and for the 5-gear tranny versions, changed from 4.08 to 3.92.  These changes had already been made to the US export models 5 months earlier though, in July '69.
A comment by MB's current (then 1990, when book was written) Engine Director made no secret of the difficulties with the cylinder wear problem in those days.  One of the points he raised was that the engineering teams had actually reached the end of the technical possibilites available at that time with the M129 and M130 engines.  He goes on to say that it was for these technical reasons that even the M110 and the V8 engines M116 & M117 of his time were developed with high compression.
In summary on the engine cylinder wall & in-line 6 cylinder thermal gradiants induced cylinder distortions, the author discusses this theme and elaborates on it as a problem area in each section related to the W113... for every version of the W113 line from the very get-go in original development of the 2.3L ... right on thru the 2.8L.
As the displacement increased from the actually original 2.2L (the 2.3L M127 engine is an increased displacement 2.2L engine), so too the thermal gradiants increased which increased the distortions and wear-out / failure rates.... and which increases therefore reqiured increasingly added mitigators which were applied successively to each engine type (M127, M129, M130) in series as they came to production.
BTW, the 2.3L engine, when it was used experimentally as the development engine for the 2.5L version that would replace it failed dramatically with the increased stroke applied to it... the failure in those experimental engines were all at the crankshaft bearings.... which is why the 2.5L & 2.8L engines used 7-main bearings instead of the 4 main bearings used in the 2.3 & 2.2L engines.
In hindsight, from my development experience in new tech, with the length of time & effort, with learning, involved by development of the 2.5 and subsequently the 2.8L engines, had the initial effort been applied to a 2.8L engine instead of a 2.5L displacement upgrade from the 2.3L engine, the likely outcome would have been a 2.8L engine introduced in '67.  Unfortunately, most of the problem's encountered with engine development for the W113 application were self-made by executive management decisions at the time (also so stated by Engelin in the book)... the reason being in essense a lack of focus and funds applied to the engine development division and in-fighting among the executives in charge of engines.
Despite these issues, the fundamental pagoda series was a resounding success for MB.  But, not parenthetically, so too was the Jaguar e-type, which over it's life sold almost twice as many sports cars as the W113 series did.... some of the additional volume was because the e-type was introduced 2 years ealier and was extended 2 years longer than the W113 series.... starting with an inline 6 3.8L, changing to an in-line 6 4.2L, and ending with a V12... skipping the V8 entirely.  We've had the discussion before on this site about the straight line speed and acceleration of an e-type being far superior to the pagoda, but the pagoda having far better handling characteristics on curves plus the added level of creature comforts... not to mention the reliability of the W113's design in general... excluding the engine's shortcomings.
On the other hand, speaking of handling, the BMW was by the late '70's and early '80's acknowledged even by the most biased MB fanatics in Germany to be far better in handling even at the top end 700 series of the BMW line.... a "drivers" car, vs the MB a "stateman's" car.... this anecdote being based on my experiences  having again lived and worked in Germany in the early '80's.
Longtooth
'02 SL500 Sport
Post by: Longtooth on September 11, 2006, 17:26:56
Just some interesting observations on the changes in HP from the 2.3L M127 to the 2.8L M130 engines used in the W113's.
Although the marketing and 'technical' data sheets list the 2.3L as having 150 HP, it rarely exceeds 141 - 143.  Increasing it's displacement to the 2.5L engine (+8.7% increase) brings only a 5% - 6% increase in HP (150 vs 142), so the additional main bearings (7 vs 4) increased frictional losses.
Going to the 2.8L M130 increased HP from 150 to 170 for the added 0.3L displacement. A 12% increase in displacement translated to a 13% increase in HP.  Obviously, the added bore made the difference in transmitting the added displacement into a 1:1 addition in HP.
Longtooth
'02 SL500 Sport
Post by: rwmastel on September 11, 2006, 21:43:04
Interesting numbers, assuming that nothing else changed. [:0]
Post by: Vince Canepa on September 12, 2006, 05:33:59
Good point Rodd.  The 250 engine was designed to increase torque, not power, hence the stroke increase and no bore increase.  Also, I believe the 250 cam is milder than the 230 (if I remember correctly the 230 cam is the most aggressive available for this series of engines).
Vince Canepa
113.043-10-001543
568H Signal Red
116 Caviar MB-Tex
Post by: Longtooth on September 12, 2006, 12:40:20
Vince,
According to Engelen's book and quotes in it from those he interviewed, the hope was that the increased stroke on the M129 over the M127 would result in substantially more HP than the M127 (230SL)... they had to settle for the 10% increase in torque, and the relatively mild 6% increase in HP over the 142 average HP achieved on the M127 though.  The marketing appeal of the 150HP M129 (250SL) was nil though since the 230SL was listed and shown as having 150 since it's introduction... but it never achieved that level (143 was max achieved on test stands) in fact.  Needless to say, MB didn't advertise the fact that the 250SL's HP was increased over that of the 230SL's, since to do so would have caught them in their little white lie about the 230SL's HP being actually less than advertised and listed in their technical literature.
The real issue MB was facing with the engine division and the development of the M127, M129, & M130 engines was always the cylinder wear / failure problems.  There's a remark in the book that describes the Autobahn stretch from Baden-Baden to Freiburg as being prime real-estate for MB 230SL repair facilities and cemetary plots for scrapped 230SL engines... which stretch of Autobahn, I recall from my living in Germany was a virtual quarter - length of Germany straight stretch with little traffic and pedal to the metal opportune "vollgas" speed driving stretch. The M127-M130 series of SL engines cylinder failure proplems are thematic thruout the entire SL series for high speed high rpm "sport" driving styles that the SL series was marketed to.
Basically, MB was unwilling to spend the development money in Engines to completely redesign their engines and then retool the engine factories to avoid the issue.  This was both a time-to-market (the SL's as replacement for the 190SL and 300SL's) and profit motive based decision.
There are many great design features of the SL series, heralded ones even... but the engines were NOT one of them.... acknowledged by MB's own executives, engineering directors, sales, and service heads at the time... though of course not publically until Engelen's book appeared with their quotes and supporting documents from MB's files in 1990.
The other area of issue with the SL's was the famous nose-diving braking effect... which lifted the rear, taking weight off the rear axel, forcing the rear wheels to negative camber as well as increasing stopping distance dramatically in high speed braking.  Of course on curves this was accentuated and led to the sudden rear end spin-out problems.  There were solutions for this... but they required a complete change of the rear end system... and this required a change to the factory's again....not something MB at the time wanted to do (spend) for the SL series.
These things were much bigger issues in the European market than in the US's... as no speed limit autobahns and highways in Germany were well utilized in that capacity... I know... I learned to drive in Germany and spent 3 years from 16 - 19 years of age driving my Volvo 1600 at full throttle 90% of the time... and the max speed I could achive on the flat was 110 mph... while the MB's high end sedans and the early ('63, '64) 230SL's were flying by me like I was standing still so to speak.  I spent 75% of my vision while driving the Autobahn's in the rear view mirror watching out for the blinking high beam lights 2 km behind me --- which told me that I had to move over to the right lane quick like a rabbit before the oncoming (probably an MB) car had to brake to keep from hitting me in the rear end.
That's a mite different kind of driving style than existed in the US at the time.... understatement.  When I came back to US at 19, and drove here I couldn't believe how slow everybody drove!!!  It was a major adjustment for me... as 90 mph was my accustomed normal freeway driving "just cruising along" semi-relaxed speed on the straight stretches.... sipping my beer (while driving) no less.  It's actually quite a wonder I ever survived those days to live to tell about it.
So you can begin perhaps to differentiate the issue with the engines failing in Germany and Europe relative to the issue in the US export market.  Obviously, with speed limits and higher traffic'ed freeways in the US, the average number or revolutions the engine's had on them over a given period of time in the US was far lower than on the European ones... hence time to failure was extended considerably for the SL engines in the US driving market.
Documented peak HP & torque for the SL series, in Engelen's book with original MB hand-drawn engineering charts for HP and Torque as function of RPM:
 - 230SL M127 - 143 , Torque 20
 - 250SL M129 - 150 , Torque 22 (with 7 main-bearings)
 - 280SL M130 - 168 , Torque 23 (with cam 1800510935 & 9.0 compression... the series that ended up in the 280SL production engine)
It's too bad that Engelen's book Vom Barock zur Pagade hasn't been translated to English... or you could read these things for yourself.
Longtooth
'02 SL500 Sport
Post by: Vince Canepa on September 12, 2006, 16:14:06
Book, scmook.  Every book I have seen is full of errors and speculation.  The cylinder dimensions, cam timing, etc. do not support the theory that M-B was looking for HP.  That is engineering - not authoring.  I happen to be an engineer, by the way, as I believe you are.
FYI, I grew up with these cars.  The major complaint of the time was that the cars had no torque.  This applied to the sedans as well.  The increased use of automatics, with a fluid coupling rather than a torque converter, combined with a 2nd gear start from rest, exacerbated the issue.  Road and Track described the 230SL automatic as so slow off the line it could be outrun by a VW.  These cars desperately needed torque, not HP, and the newly established M-B of North America was telling that to the Germans.  On top of that, BMW's six cylinder cars had hit the market with greater torque at  the same HP and better fuel economy.
Despite the author's thesis, the entire series of engines were known for their long life.  I pulled mine apart at 117,000 miles and cylinder wear was negligable.  My driving was wide open throttle as much as any European.  I drove the coast from Santa Cruz to San Francisco two or three times a week.  I could make it from Wharf Road in Capitola to the corner of Third and Harrison in SF in one hour flat.  That is as hard (time spent at full throttle) as any Autobahn driving.  The result - we nearly skipped the overbore to the first repair size the wear was so low.
If there is a problem with these engines it is the head design.  They don't breathe well.  Designed in the early fifties, they carried on practices M-B started in the 30's.  The non crossflow head has a poor combustion chamber shape and the ports are crowded (interestingly, the present day VW VR6 has the same issue but they were able to increase torque with a variable length intake).  M-B finally tried a DOHC head when these engines evolved into the M110 in the late 60's, but the writing was well on the wall.  M-B at the time was a very conservative company.  Everything about their cars was old fashioned.
Vince Canepa
113.043-10-001543
568H Signal Red
116 Caviar MB-Tex
Post by: glennard on September 12, 2006, 19:51:24
Longtooth, My '64(Oct) has the pancake expansion tank.
Post by: Longtooth on September 13, 2006, 03:24:06
Vince.... I take it then you disagree with the MB executives & engine engineering directors, the MB service executives, etc. that are quoted in Engelen's book.
BTW, I found the correct translation for "gefressen" as refered to in the cylinder wear problem ... it's in my BBB with German Text describing the pictures of different degrees of cylinder wear.... with the English terms for each level of wear listed below this.... the English word for engine cylinder "gefressen".. past tense of "fressen" is "Seized"... so the "grosse Fressen" refers to the engine seizing problem in cylinders 1 & 2 predominantly.
Yes... I am an engineer.. mechanical... and have spent a large part of my career fighting the fundamentals... differential CTE's, heat transfer rates & capacities, thermal gradiant induced high localized stresses... cyclic fatigue fractures, tribological wear mechanism's... you get the picture... I'm relatively well versed in these issues as they relate to fundamental root causes of wear & failures in metals and ceramics.
I'm not an automobile engine engineer... but I have worked with some that joined our company from r&d at Ford and while I worked in Germany and England, a couple that had worked at MB's engine division in r&d.  I didn't learn any particulars about their research at that time (I wasn't interested, nor were they), but they all said that compared to the methods and approach we used in r&d that Ford and MB were still in the dark ages.  In essense, I was convinced that the approaches used thru the 80's in the automobile industries r&d divisions left a lot to be desired.  For example, while we were researching the sensitivities of compound interactive variable tolerances on the systems, using multivariate statistical methods and upwards of 300 - 400 asm's or sub-asm's for each of several variants, Ford and MB were using numbers in the 10's to 20's and thereabouts.... and which largely relied on grossly empirical results.  While our modeling efforts were advanced and had evolved with more and more knowledge over time, the automobile's mechanical modeling in r&d were not nearly as sophisticated... and more often than not the models didn't match the empirical results in triboly or even fracture locations.
I'm not surprised therefore that in the late 50's and early 60's the methods were far more empirical and even less sophisticated than they were in the 80's.  Hence, I'm also not surprised that for example, the engineering team didn't know they'ed need 7-main bearings for the M129's higher stroke engine to prevent excessive loads on the 4 main's used in the M127.... before the tests showed them the failures occurring in dramatic fashion.  Now, to be fair, there may have been some good engineers that screamed to their superiors that the mains would fail with 4 main-bearings... but the fact that they didn't start testing with a 7 main bearing engine in the 1st place, and that the product (M127) was delayed as a result, only indicates either the engineer's at the working level didn't know, or that the approach used was purely empirical.... 'try it and see what happens.
Empirical evaluations in development are the name of the game... so I'm not saying it's a bad aproach... and has to be used ultimately in any event to verify whatever engineering sub tests or calculations indicate.  But some things are just fundamental.... surface stress to surface failure at temperature and pressures (load) based on surface finish and viscosities of lubricants under loads and temperatures.  If you're going in the direction of increasing HP, by increasing displacement or increasing compression, you're in effect required to increase the forces acting thru the piston to the crack shaft and on the mains.  Maybe it's just me, but it seems rather a fundamental of engine mechanics that the r&d team would have known how close to bounderies of metal surface fatigue they were before they even contemplated increasing stroke on the 2.2L engine. Or maybe they did, but then why force a delay in the program by waiting for life reliability testing elapsed time to show that????
And, btw, you can't possibly drive like the Germans did going from Santa Cruz to SF no matter how hard you think you were pushing it.  I lived and drove in Germany when I was unaware of the possibility of death or maiming myself... i.e. fearless (16 - 19) and risk prone... though to be honest, I didn't see it as a 'risk' at the time.  I've driven & lived in the bay area since I was 20... Santa Cruz being a frequented haven in spring and summer from SJ and SF/Oakland environments.  For one thing, you weren't passing on blind curves and blind hills winding out to 6k rpm on every acceleration either.  For another, the SL's and other high speed vehicles in German drove the straightaway's on the Autobahn's full near throttle between gassing up... if they had to let up on the throttle it was because the curve they were going into was a tad to sharp for the speed... otherwise, if they had to pull off the throttle because somebody was in front of them going slower horns would be blaring, fists shaking, and high beams blinking, while they rode your rear bumper with an inch clearance.  In short, the discipline of driving in Germany at that time was such that if you were in a slower car than the one coming up behind you, then you were obliged to move over before the upcoming car behind you was forced to pull off the throttle... much less have to brake.  This was common curtosy, since every driver, in slow cars or not, wanted to eventually be driving a faster one and have the slower car's pull over for them when they were able to achieve that level of car in their life-time.  Sitting back driving relatively slower in the fast lane just wasn't done... anymore than stopping in the middle of the freeway.
So... when's the last time you sat on the throttle at over 6k rpm for 2 hours at a stretch without letting up more than 500 rpm on rare occasions?
I'll go with documented evidence in the book which is consistant with my experiences driving in Germany at the time.
By the way... I did say already in one of my posts on this thread that the US market wanted acceleration at low speeds... so torque was the US market quest.  Europe wanted high speeds and acceleration at high speeds... i.e. from 80 - 120 mph in a blink of an eye... not speed off the mark.  While the US muscle cars were laying screaching rubber off the mark, thru each of 3 gears (read high torque), the Europeans were watching the results at Lemans 24 hr indurance races for which car's had the best longevity at high speeds.  The US's stock car racing at the time was as you must certainly know, not the mark of endurance at high speeds... 100 mile races were even then in the rarified stratus of stock car racing with the US muscle car's oval track racing circuits.
One of the statements in the book quoted from an MB official at the time was that the holy grail was that in the early '60's the everyday driver could buy a car that would go 200km/hr ... and many European automanufacturers had achieved this milestone 2 years before MB's 230SL hit the market.  There was immense concern by the board of directors that the 230SL wouldn't achieve the 200 km/hr or more top speed.  They barely hit it in fact... and breathed a great sigh of relief since with that 200 km/hr moniker they could stick with the 'sports' car image they'd left behind with the 300SL.... and that image meant sales.
So I beg to differ with your opinion that MB was after torque.... they were after a 200 km/hr engine... and high speed acceleration... not torque... they needed torque improvements, to be sure, but that was not their primary endeavor in the engine division nor for the SL series.  It was only after the 230SL that they they wanted to increase the torque (from the auto mag's testers comments related to slow time off the mark).... but they were still after horsepower as primary.  The US Daimler Benz of North American's heads came to Stuttgart during the 250SL engine development... and they and the VP for MB sales said they didn't need to push the 250SL any faster to market, nor accelerate the 2.8L engine's development since sales in the US were accelerating at an accelerating rate already.  In fact, their biggest concern, and that of the board was that the rumor of the 250SL being an imminant introduction (1 year before it was announced) would shut down the sales of the 230SL in US and Europe... in anticipation of the 250SL coming to market.  A great effort was put in place by MB to quash all such rumors and they put tight security on the development work going on with the M129 engine.... even though that engine was introduced already by then  on the W108.
By the way, do you mind my questioning your source information from MB and documents pertaining thereto?
Also, btw, I've at various times on this site, stated that I'd purchased my 250SL in '84 and drove it a couple years before letting it sit for the next 15.  ... and that the reason I stopped driving it was that it was weak in one of the cylinders, and smoking oil at an increasing rate of consumption.  That was at 106k original miles on the engine. It had had always had a little lower compression in that cylinder and a little smoke & spark plug fouling faster in that cylinder than the others even when I bought it, but it got progressively worse.  I purchased the car with 103k miles on the engine. The diagnosis when the head was removed --- to determine the extent of the problem... was that the cylinder was worn and compression ring fractured.... so I decided to have the engine rebuilt (long block) by Metric Motors in LA.
Was I surprised that the engine needed work on the cylinders and head at 100k miles?  Not at all, and not in the least.  Would I have been surprised if the engine siezed & needed to be replaced (beyond reboring) at 50k km's (~30k miles) ???? you betcha!... and especially if I'd paid what the then going rate was for an SL at the time.
Finally, relative to Engelen's book... His research and documentation is well regarded from what I've read.... and there's been no smear campaign by MB to discredit his book or information... though the books been out since 1990.  The book is fundamentally a documented history of the developments & changes in the SL series vehicles from the 300's,  190's thru the 280sl's, both from the perspective of decisions made by upper management and the board, as well as technical details involved in these cars and their effect on their successors. I've seen no claims or remarks of a negative or positive nature in the book so far that isn't supported by quotes from MB and documents from the time from MB or the automotive test results by both MB and the automobile magazines.  keep in mind that if the author's work was to have a credible basis, he had to remain objective in his reporting... otherwise nobody'd have paid any attention to it if it were highly biased to one side or the other... therefore, I believe Engelen's done a credible job of reporting on the negative issues that occurred within MB and the SL's as well as the accolaids they won and the accomplishments made.
The book is highly technical.. not written in an historical "novel" style, and for most readers would be too technical in nature to hold interest for very long... so it's intersperced with pictures and short captions to solve that problem.... along with relatively larger type font and highly calendered paper.
The item that started this was a suggestion to use Enelen's book for dates and chassis numbers that identified what changes were made to each model.  There are over 10 pages of this detail listed... almost all of them on the 230SL's changes.  I had previously surmised and conjectured about why the 250SL was so quickly replaced by the 280SL and ventured that the reason was related to the US DOT regulations changes that required smog and other HP robbing conditions so that they 250SL's HP was replaced by the 280's to continue to reap the rewards being had in the US market.
Klaus then quoted loosely from Engelen's book on a section that desribed a wear-out failure problem with the M127, 129, & 130 engines and used this quote to describe it as the reason for the replacement of the 250SL by the 280SL. Naj then requouted from Klause's quote and inserted the words "[of the 250SL]" to more directly state that the engine problem was a 250SL engine problem.  I've read Englelen's book extensively since then and found not only was Klause's quoted statement taken out of context in refering to the 250SL being replaced by the 280SL, but that naj reinterpreted Klause's quoted statement even more wrongly as applying specifically to the 250SL's engine.
Since those posts, I've reported on other aspects of the engine wear problem from my reading of the book thus far from the 220SL (there was one, you know... just not brought to production) to thru the 280SL.... and to summarize once again ... it was an inherent issue with the entire series... becoming worse with each increase in Horsepower, requiring increasingly more and costlier changes to mitigate and move the problem out in time.... and ultimately compromising the SL's potential Horsepower which could have been achieved had the "Zylinderverzug" problem not been so dramatic.
I've also clearly stated that this was probably not as big a problem with the US market for the car due to slower speeds (speed limits) and the American attention therefore to "off the line" time.... i.e. torque intensive attention.  The US paid attention to Max speed in the literature, but not as a practical matter, as in fact they couldn't use it anyway outside of as a flat out race car... who was going to use it to go 125 mph other than maybe 1x for 1/2 mile just to check it out once.  In contrast, the high speed autobahns and German/European driving culture in post-war Europe on Germany's no speed limit Autobahn's and to a very large extent their Highways (Bundesbahn's) made for extensive use of high speed driving in the 160-180 km/hr range a common occurrance for the higher end, high priced cars. Like I said, I drove my Volvo B1600 Sport 4 speed stick at full throttle (~110 mph) most of the time on the autobahn and near that on the highway's, though more curves and traffic that I couldn't pass due to directly oncoming traffic slowed me down a little.  I've probably driven in excess of 100mph up to 125 or so for an extended 5-10 miles (ha) maybe 20 times in the past 30 years in the US.  On each occasion I've either been back to German to visit or work or live, I've driven at that speed for an hour our more at least 2x per week while there..... even with speed limits now on much of the autobahn system... as long as the traffic would allow it, I was able to drive at those speeds without too much consideration for somebody arbitrarily pulling out in front of me with little or no warning from the right hand lanes. Traffic on the autobahn's and their relative lack of having been widened extensively in the recent past has dramatically reduced average speeds and especially the free driving 100 mph + speeds... not to mention the more extensive use of speed limits now. Gasoline consumption increases with increasing speeds as well, and with more and more taxes in Europe on their Gasoline, this has also decreased speeds in general.
The reason that the Zylinderverug "fressen" problem is thematic thruout the SL series development and version to version in Englelen's book is simply that it was the limiting condition for the time-lines for introduction of each model and the limiting factor in HP and performance and not simply solved without going to great expense in MB's factories... which they didn't (obviously) chose to do.  The problem was never solved... and at best pushed out in time (use)... mitigated, but not fixed.  Do you want to know why MB lists Oil mfg'ers and Oil grades from each in the owner's manual?  Because MB ran tests on them to find out which ones mitigated the 'fressen' problem and which made it worse!... that was one of the executive boards command decisions... spend the money and evaluate oil mfg'ers and grades.... among other command decisions to find ways to mitigate the problem.
It's not my intent to be derogatory about our beloved SL's... rather simply to provide some of the information all the SL owners would perhaps like to know more about.... and had Engelen's book been translated and published in English in the early '90's the items he's brought to the light of day would be well known by the US SL owners public by now.
Longtooth
'02 SL500 Sport
Post by: Vince Canepa on September 13, 2006, 06:16:07
Longtooth - My response will be brief.  There is no point in me going further with this discussion, as I don't have the time or inclination to write or read endless responses.  I do have personal knowledge of the development of these cars that comes from inside the M-B organization, where several of my acquaintances worked.  It always amused us that the Germans would act like the US market didn't matter and that US drivers didn't understand the cars, yet behind the scenes they were furiously working to address US complaints (as in the development of the V-8s that took place all through the 60s).  I would offer that the author's knowledge is not in fact much more than that, anecdotes and casual discussion, unless he is producing actual documents.
Also, try to make the run up the coast that I describe without "winding out to 6k rpm on every acceleration either".  I also made several runs from Scotts Valley to Temple City - 375 miles in 4 hours.  I would pick up I5 in the valley, before it was opened, go around the barriers and run wide open from 46 to the intersection with the old 99.  In fact, I find that to get any performance out of these cars today I must still drive them wide open "winding out to 6k rpm on every acceleration", with all the attendant racket that goes with it.
Vince Canepa
113.043-10-001543
568H Signal Red
116 Caviar MB-Tex
Post by: glennard on September 13, 2006, 06:48:55
Interesting discussion.
Post by: Longtooth on September 15, 2006, 04:09:10
Vince... I can only say that before you can comment on whether or what the author describes, and what documents he shows or quotes from the MB executives and minutes of executive meetings, and engineering charts, you need to
1. Learn to read German (if you don't already), and
2. Get the book or borrow a copy and read it.
I think you're trying to say you don't believe the author's sources are valid or verifiable.  I believe they are.  That's the only difference in what I perceive to be your disagreement with what I've posted on this topic.
BTW, the author gives exclusive and total credit for the entire SL series (beginning with the 190SL's conception and execution) to an American... and the influence he had with the Executives and Board of directors at MB to design and build it... for the American Export market!!!!!  Had this American not gone to MB and addressed the Board (at the Board's request), the entire MB "sports touring" SL's would never have existed.... according to the author.  That's not to say however, that the American market was using the cars like the Europeans were... and the sports car market competition was determining that HP was king... which was the reason for MB's emphasis on HP improvements since the perception --- emphasis is perception ---- of the American market buyers as well as Europe's was that the higher the HP the better the car, all other things equal... what MB and the American Import market knew however, was that the American's proof of performance was "off the line acceleration"... while the German's was high top speed and high speed acceleration.
And, I haven't read anything in the book, nor reported anything that said the American export market didn't matter to MB... and in fact the American market was a major reason for the decision to replace the 230SL with the 250SL, despite the marginal improvement in HP, but with a 10% improvement to torque... which improved the 'performance' in low speed application as in "0-60" times, etc... the MB Export Sales Chief argued vehemently that there could be no delay with replacement of the 230SL... with the 250SL, as the 250SE was already on the market nearly a year earlier than the 250SLs introduction, and he, and the BOD feared the loss of sales in the growing US market if the rumor's persisted that the 230SL was being replaced with the 250SL.
So it's not my understanding from the author that the US market 'didn't matter'... it sure appears to have mattered to the MB executives that ran the business... and the engineering leads that directed the engine development. It was the MB board that invited the American to address the Board with what would sell in the US market... before there was even a clue within MB (not even a concept drawing or sketch... not even a set of performance criteria or outline... not even a concept) as to what came to be the 190SL and it's follow-ons... 230SL, thru the SL's of today.!    I think your acquantances from "within MB" were not those that had to do with decision making since, as you said, "...the Germans would act like the US market didn't matter and that US drivers didn't understand the cars, yet behind the scenes they were furiously working to address US complaints (as in the development of the V-8s that took place all through the 60s)."  So those acquantances of yours were ill informed with respect to their leadership's perceptions of what was important... apparently. "Behind the scenes" is how all company's work in a competive market place isn't it?  At least that's been my experience in development... we sure never leaked or marketed anything before it was ready to go into full production in my business... even before we had any competion (since it would halt or vastly diminish current sales)... and in the current highly competitive market it's even far more critical to make sure our development activities remain "behind the scenes".
Your argument isn't with me... at least I don't think it is... it's with Engelen and his documented sources from within MB.
Like I said... I can only suggest you read the book before you take exception to it's content. What you'll find is that the decisions made were business decisions... based on market competition and market perceptions,  and those decisions dictated the technical ones related to chassis, rear suspension, and engines, and timing (i.e. time to market).  MB broke the sports car concept mold with the sports "tourer" SL series... a blend of a sports car and a GT... comfortable accomodations & drivability with sports car appeal.  The engine problems I've described limited MB's options in market timing and what they could offer.
Longtooth
'02 SL500 Sport
Title: Re: 250SL's Differences
Post by: Benz Dr. on September 15, 2006, 14:39:26
Unbelievable....... like, don't you have a day job or something? ( lol ) Maybe the book has valid points but I'm not about to go and buy one nor do I care much about it's contents. I fix the real world problems of age and wear... the causes of which are many. I doubt the author of this book ever got his hands dirty or knows one end of a wrench from the other.
I've seen plenty of cylinder wear but never cracks between cylinders. MB stated way back then that normal cylinder wear was roughly .001'' per 10,000 miles of driving. Care and driving conditions can greatly affect this but I can't understand why no one could lose the meaning of carb versus injected engine wear.
 A carbed engine isn't as highly stressed as the fuel injected variant but there's more to it than that. The injection pump will deliver the same amount of fuel regardless of how worn the engine might be or how high the compression is. In other words, the pump is set at or near optimum compression numbers. Low compression will mean poor cumbustion leading to fuel dilution and increased wear. This isn't rocket science......
Even modern engines in new cars fail, although not that often. A small or moderate failure rate 40 years ago is of no real consequence today. To say that the 250SE/SL engine is a piece of junk is as silly as the idea that 3 extra bearings somehow produced some kind of huge drag or friction within the engine. This was and is considered to be a stronger system ( 7 main bearings ) and if they didn't get the design right it takes nothing away from the real improvement.
The fact that late model engines ( 280SL and /A )run hot, IS born out by the info you gleaned. I already said why they run hot and I hold no sort of degree regarding design or metalurgy. They run hot because of the design and size of the cylinders compared to the size of the block which is after all, a modifed 220SE.
Please try and hold back any response to maybe 6 or 7 pages. I have a hard time staying awake these days....
