W113 Pagoda SL Group => Electrical and Instruments => Topic started by: BaronYoungman on May 20, 2008, 07:36:27
The key which worked fine before won't turn. I pulled it into the shop OK but when went to move it into the spray booth the key fits in but wont turn to unlock the wheels. I know it has something to do with the steering lock....but what do I do? Don't want to break the key in the lock!
Jiggle the steering wheel, if the tire is against a curb or whatever causing the steering shaft to hold pressure against the locking pin, the key will not turn.
that did it!!!!!!
THANKS
