W113 Pagoda SL Group => General Discussion => Topic started by: n/a on November 07, 2003, 08:11:12
Title: Radiator hoses
Post by: n/a on November 07, 2003, 08:11:12
I'm about to replace my radiator. Should I do anything special about hoses? Are some better than others?
Shawn Rock
Philly, PA USA
1968 280 SL 4 speed
Title: Re: Radiator hoses
Post by: rwmastel on November 07, 2003, 14:43:46
I have always heard to use genuine MB hoses and this has come from many sources.  I guess they really last longer and possibly give you a hint of failure (bulging) before failing.
Don't forget how many you have:
- supply & return at radiator
- supply & return at heater core
- supply & return at F.I. Pump thermostat
- supply to overflow/pressure tank
- thermostat bypass
Did I forget any?
Post by: ja17 on November 07, 2003, 22:33:30
Hello Shawn,
The original hoses are a little expensive, however they will last twenty years or more!
