Author Topic: NOTICE: MB part numbers for Instrument and Heater Bulbs  (Read 4027 times)
JPMOSE
  • USA, DE, Harbeson
« on: December 30, 2008, 21:34:06 »
The following Mercedes part numbers apply to bulbs utilized in the instrument cluster, clock and heater controls:
1)   2W bulb used on everything except the heater controls:  N072601 012800
2)   2W bulb used on heater controls (2 each):  N072601 012110
3)   4W bulb used as an option for illuminating the instruments and clock:   N072601 012900
Please note that the Mercedes Electronic Parts Catalog (EPC) shows the SAME part number for heater controls and instruments/clock.  This is incorrect, as the heater bulbs have a different bayonet fitting.
The 4W bulb has been referenced throughout this site to better illuminate the instruments and clock.  This would require 7 bulbs total:  2 each for the Tachometer; 1 each for the Center Instrument Cluster; 2 each for the Speedometer and 1 each for the clock.   It should be noted that there are six (6) additional bulbs in the Center Instrument Cluster for turn signals, low fuel light and 3 idiot lights...these should remain as 2W bulbs
« Last Edit: January 03, 2009, 20:34:29 by JPMOSE »
Best Regards,
J. P. Mose
1968 250SL
1970 280SE 3.5 Cabriolet
1987 560SL
Re: Need MB part number for Heater Bulbs
« Reply #1 on: December 31, 2008, 14:44:15 »
I did a quick search with "bulb" as the topic only looking at the title.
Here is one thread
http://www.sl113.org/forums/index.php?topic=8678.0
