Author Topic: Engine bearing tolerance  (Read 4032 times)
hakan
« on: January 22, 2009, 12:39:29 »
I want to get information at Engine bearing tolerance
To 230sl
menesesjesse
  • USA, MD, Indian Head
Re: Engine bearing tolerance
« Reply #1 on: January 22, 2009, 13:21:33 »
What tolerances are you looking for?  Rod Journals? Crank Shaft journals? Piston End Gap? etc. I have them in a book at home.  Email me and I can send the info over to you. menesesjesse@juno.com
Jesse
1966 Mercedes 230 SL auto
2003 Mercedes E500
1992 Ford F150
1994 Ford Bronco
2019 Shelby GT350R
1967 Mercury Cougar XR7
« Reply #2 on: January 23, 2009, 01:34:33 »
The crankshaft main bearing clearances are;
radial...............      0.045-0.60 mm  (0.050 mm best)
axial................  ( controlled by flanged bearing).....  0.1 - 0.175 mm
The rod bearing (big end) clearances are;
radial:   0.045-0.060 mm  (try for 0.050 mm)
axial when new.....  0.11 - 0.26 mm    after repairs  up to  0.5 mm
See Technical  Data Book July 1963 edition p. 114
« Last Edit: February 05, 2009, 04:02:57 by ja17 »
pauldridge
« Reply #3 on: February 04, 2009, 12:29:26 »
For Joe,
You stated .5mm clearance for rod bearings.  Is that a misplaced decimal point?  That seems way excessive??
« Reply #4 on: February 05, 2009, 04:05:42 »
Good catch Paul,
I listed the axial as radial. The post is corrected and I will send a message to hakan!
Joe
