I have removed the engine from my 1966 230 SL (automatic) and I had - as outlined in the Haynes manual marked the flywheel and the transmission accordingly to ensure alignment. When the I had to put engine back in, the shop which overhauled the engine, had removed the mark on the flywheel, which means that I can't be sure that the engine and transmission is aligned, when I put it back together. Is this a big problem and if so, what to do ?
