Author Topic: It stopped ...  (Read 2949 times)
It stopped ...
« on: February 13, 2009, 22:58:59 »
After about 5 seconds after starting the car this evening from cold, it stopped very abruptly. I thought 'ignition' and checked for a loose wire, but to no avail. Then looked at the fuses and, sure enough, one of the 'stubby' ones had failed (or succeeded, depending on how one looks at it). I replaced it, started up again and, again after about 5 seconds, the car stalled. Fuse blown again. I then noticed that the battery ground (-) cable was touching the ballast resistor. Last evening I replaced the battery and did not route the ground cable properly. After fixing this, replaced the fuse one more time and this did the trick.
I was pleased that I was able to pinpoint the problem so quickly, but was also embarrassed I had caused it ...
Re: It stopped ...
« Reply #1 on: February 13, 2009, 23:12:01 »
Congrats of solving the problem.  No one likes to admit solving a problem they created but its still satisfying to have done so.
