Author Topic: Pulling Transmission and Dyno Testing  (Read 3360 times)
Nate
  • Mill Valley, California
« on: February 20, 2009, 17:30:37 »
I pulled the automatic transmission out of my 1971 280SL to be dyno tested.  The transmission was operating fine, but I'm finishing up my restoration and decided to have all the mechanicals gone through.
The transmission is at one of the best MBZ transmission shops on the west coast.  Is there anything that I should have them replace while it's off the car, such as seals, switches, etc?  Is there anything that you would not touch if the transmission was operating fine?
Arabian Gray / Dark Red Leather
2013 Porsche 911 Carrera 4S Coupe
Black on Black
2013 ML350 4MATIC
Arctic White on Almond Beige
Wife's car that I get to drive
1964 Porsche 356C Coupe
Irish Green on Black
Black Plate CA Car
Unrestored
Re: Pulling Transmission and Dyno Testing
« Reply #1 on: February 20, 2009, 22:41:03 »
Once you start it is hard to find a place to stop.  At the very least, I would replace the front and rear main seals, the filter and pan gasket.
After that all rubber seals, o-rings and gaskets. Once you have gone this far and this deep you will probably not be far from all new clutches being replaced etc, etc.   Complete rebuild?
If yours has the riveted torque converter hub, have them pressure check the unit for leaks.
Nate
« Reply #2 on: February 25, 2009, 03:47:15 »
Thanks for the suggestions Joe!  I have the solid steel hub, so hopefully everything is in order there.
Black on Black
2013 ML350 4MATIC
Black Plate CA Car
Unrestored
