Author Topic: Spray pattern of fuel injector nozzles  (Read 3037 times)
jpressick
  • USA, VA, Poquoson
« on: March 13, 2009, 19:03:35 »
Recently my injector nozzles were cleaned and tested.  The test showed all six had a 180 degree spray pattern as opposed to the 360 degree pattern expected.  Anyone know what the spray pattern is supposed to be.  Cheers Jim
menesesjesse
  • USA, MD, Indian Head
Re: Spray pattern of fuel injector nozzles
« Reply #1 on: March 13, 2009, 19:31:33 »
I checked the spray pattern for my injectors at home with a pump.  I got 360 on all of them.  I had to replace 2 due to because they operated at the wrong pressure.
Jesse
1966 Mercedes 230 SL auto
2003 Mercedes E500
1992 Ford F150
1994 Ford Bronco
2019 Shelby GT350R
1967 Mercury Cougar XR7
« Reply #2 on: March 21, 2009, 03:09:22 »
The spray pattern is cone shaped and fuel should emerge in a  360 degree circle at the injector nozzle. I am not really sure what the 180 degree pattern refers to with your injectors?
