Author Topic: Project engines/cars  (Read 4375 times)
glenn
« on: March 14, 2009, 00:48:57 »
Re: Engine rebuilds, etc.
Correct me, if i'm wrong, but isn't having 5 or 6 project engines/cars 'Normal'? (See Cees.) If you don't, consider yourself deprived and underfulfilled.  If more, certain people in America were fortunate enough to have this condition, it would be a better country. Anybody have a spare '67 250SL  piston?
JimVillers
  • USA, VA, Virginia Beach
Re: Project engines/cars
« Reply #1 on: March 14, 2009, 01:09:50 »
Glen .... I agree, extra engines are good.  I have three spares for my 190SL and am curently rebuilding one that I'll swap into the car this spring.  I would have a spare for my 230SL is I came upon one cheap.  Keep your eys open, cars are junked every day and a sedan engine can become an excellent spare.
Jim Villers
« Reply #2 on: March 14, 2009, 04:03:11 »
Uh.... what size piston are you looking for? Standard, .5mm or 1 mm over?
glenn
« Reply #3 on: March 14, 2009, 11:34:13 »
Doc, Piston comment was kinda 'tongue in cheek'.  But, I have 12 stuck in their cylinders.  6 still have the head on with one showing anti freeze in the plug hole.  The other block shows #1 piston with a valve imprint(intake if I remember correctly) and maybe a crack.  The other 5 seem whole, but stuck also.  Both blocks are in 'soak' therapy.
« Reply #4 on: March 16, 2009, 20:12:03 »
Don't feel bad if you can't free up the pistons. My car sat in a heated garage for 28 years and due to some reaction of the aluminum pistons they literally grew or corroded themselves into the cylinders. I ended up beating them apart to get them out and was able to hone the bores without having to oversize them(it's a 280 and I wanted to keep the cylinder walls as thick as possible) I was unable to source new stock pistons without resorting to Mercedes prices but was able to acquire a used set of nice stock bore pistons for the sum of $5 apiece from Joe Alexander.
The big thing is to avoid damaging the connecting rods when you are beating out the pistons. I think I used a long piece of rod on the wrist pin boss of the pistons and a BIG hammer to finally get them out.
glenn
« Reply #5 on: March 19, 2009, 14:51:12 »
My current'solution' is to fill the block with water, heat it with a dip stick heater to 200, then put dry ice atop the pistons with cardboard on the cylinder walls.  Hopefully a 300 degree temp difference will free up something???  Then a tap with hammer on a 2x2 on the piston------
