Your automatic transmission is influenced by several inputs. Position of the three speed solenoid, engine vacuum, and engine rpms.
The linkage position can effect all three of these inputs.
The 233 mm measurement is a good starting point but can vary slightly as long as the position of the venturi remains correctly closed. In other words, remove all linkages, when the injection pump linkage is on its stop, the venturi linkage must be all the way closed and be on its stop! Adjust the pump linkage to 233mm, next the long linkage at the intake should be adjusted and fall in place. The smaller linkage rod going to the linkage swivel on the block should be adjusted so that the venturi opens all the way at full throttle but still allow it to close all the way at an idle.
With the venturi all the way closed and the linkage on the venturi on its stop, the switch on the venturi should be activated so that the three position solenoid is in its rearmost position. The transmission linkage should move to the middle position as the engine linkage is moved and this should happen around 1,000 to 1,200rpms (adjust the switch to this spec).
The frontmost position of the transmission linkage (side of transmission, inside access cover)should only be achieved if the accelerator pedal is pressed all the way to the floor and the kickdown switch under the pedal is depressed.
If setting the linkage up correctly does not achieve the correct results you may have to check the modulator pressure and adjust and/or possibly addjust the transmission linkage (side of tranny).Along with the correct pressure readings you will need to refer to the specs on the speeds for shifting up.
In most cases, if your transmission shifts too late or too abruptly, and the last downshift nearly jerks you out of your seat, a good correct linkage and venturi adjustment will do the job.
On rare occasions, modulator pressure adjustments are needed, especially if these setting have been altered in the past.
Keep us up to date!
