Author Topic: cleaning the soft top  (Read 4434 times)
  • USA
« on: April 03, 2009, 14:48:04 »
Hi everyone,
In trying to get my 220SL ready for the first spring drive, I'm trying to clean the soft top.
The top has been up for a while in the garage and has a array of dust, dirt, sawdust and whatnot.
How do I clean this off with out pressurized air?
I tried a sticky big lint brush and it helps, but not along the stitch seams or joints.
Walter
1967 220SL-diesel
  • USA, WI, Mequon
Re: cleaning the soft top
« Reply #1 on: April 03, 2009, 14:57:30 »
What's wrong with pressurized air?
How about a stiff bench brush and a good shop vac.
I never wash my top.  Primarily just regularly use a bench brush to give it a good regular brushing.  I even do this on my BMW daily driver, top hasn't been washed in 7 years.
k
RAGG top
« Reply #2 on: April 03, 2009, 15:26:28 »
http://www.haartz.com/en/consumer_info/cleaning/cloth_top_cleaning.asp
Water runs off black....off seemingly clean tops
  • USA
« Reply #3 on: April 03, 2009, 15:55:24 »
Thank you John and K,
I dont have any pressurized air to use to wash, but the brush seems a good way to go.  I'll buy a new one on my next trip to the car show/flea market.
I have not washed mine in a long time since I put it on about 4 years ago.
Walter
1967 220SL-diesel
  • USA, WI, Mequon
« Reply #4 on: April 03, 2009, 16:35:32 »
The brush is nothing special, most hardware stores carry them.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=1072
RaggTopp products are excellent, I've used them for years.
« Reply #5 on: April 14, 2009, 01:20:39 »
Good fine.
When I had my detail show and got in Canvas tops I found they hold a lot of dirt.
Using a medium course brush and following with a vacuum cleaner tool helped to remove
the  first part of the soil from the top. I liked a company that  is called Ragg Topp they were suppliers
to canvas awning and had a wonderful canvas spry cleaner  and a sealing spray that when curred by sunlight
or a hair dryer would put a polymer coating on the canvans that repelled water.
They were approved by Hartz canvas tops.
graphic66
« Reply #6 on: April 14, 2009, 20:50:47 »
Watch out using compressed air to clean things. Most compressors have some oil blow by into the tank and spray out a very fine mist of oil in the air. They do make oil separators for your compressor to eliminate this, mostly used when painting I believe.
