Author Topic: How to test the viscous clutch to make sure it is working  (Read 4809 times)
How to I check the fan  clutch to make sure it is working properly. I would appreciate any information especially if it is in the technical manual on line?
Sincerely
1968 280SL
graphic66
Re: How to test the viscous clutch to make sure it is working
« Reply #1 on: April 05, 2009, 16:17:21 »
I have always just spun them by hand. You should be able to feel the hydraulic effect in the hub. It should have some fluid resistance and not just freewheel. When I have seen ones go bad they just spun and to get back home we drilled a hole right through it and screwed a bolt in and had a direct drive fan. This was on a crap old Heap out on the trail, not a nice car.
« Reply #2 on: April 05, 2009, 18:36:08 »
There was a post on the forum some time ago (search on "newspaper") for another way to test the fan. Roll up a newspaper, and with the car at idle and warm, carefully try to stop the fan with the paper. I tried this on man, and the fan was working quite well. I did not see a response to the post, but this was one suggestion.
johnd
« Reply #3 on: April 05, 2009, 20:52:34 »
I have had intermittently working ones before on other cars.  Shopped around replacement ones are $40 . . .. so don't waste too much time messing with them.
johnd
jameshoward
« Reply #4 on: April 05, 2009, 22:06:22 »
John,
Where did you see them for $40??
I have one that is suspect (and have seen the same newspaper thing) and would gladly replace it for $40 (including shipping, naturally) rather than ruin a perfectly good Sunday Times.
Link please!!!
James Howard
1966 LHD 230SL
