Become a
Full Member
Emergency Contact List
Body, interior, paint, chrome, and cosmetic items
Hood/Bonnet seal
Topic: Hood/Bonnet seal (Read 5726 times)
Ulf
Associate Member
Gold
Denmark, Fredericksberg, Rungsted Kyst
Hood/Bonnet seal
April 14, 2009, 10:39:46 »
I've noticed a lot of water assembling in the engine compartment underneath the coolant expansion tank after washing the car as the hood/bonnet has no rubber seal. I've searched a few websites for such a seal but it doesn't seem to exist...can this really be true?
Best regards
Ulf
1965 230 SL in silver (DB180)
2008 Jaguar XF 3.0
2005 Mini Cooper
Associate Member
Platinum
United Kingdom, Surrey, New Malden
Re: Hood/Bonnet seal
April 14, 2009, 10:59:56 »
Ulf,
There is no seal but there is a drain hole in that cavity which is often blocked.
I will try to find a picture and post it later.
Reply #2 on:
April 14, 2009, 11:57:47 »
Naj,
Is this the drain hole you are thinking of?
Associate Member
Platinum
Reply #3 on:
April 14, 2009, 12:37:15 »
Yes, Bob,
Thats the one!
Is there a similar one under the brake booster?
Last Edit: April 14, 2009, 12:39:44 by naj
Reply #4 on:
April 14, 2009, 17:12:13 »
Here's the drain under the brake booster...
Note 100% perfect design... I still get a bit of water that will pool behind this drain hole after I wash the car.
I just go in and sponge it up....
Last Edit: April 14, 2009, 17:16:53 by bpossel
Associate Member
Platinum
Reply #5 on:
April 14, 2009, 18:23:56 »
Thanks, Bob,
Not seen that one before!
jharkin
Inactive
Regular
USA, AZ, Chandler
Reply #6 on:
April 14, 2009, 23:19:05 »
i try to avoid driving in the rain, and since i discovered Griot's spray wash, i haevn't used a hose on the car in months, but when i did wash the car these little puddles were another reason rt drive it around to clear them out of the engine bay...
68 250SL White over Blue manual
84 280CE Lapis Blue auto
67 250SL Silver Gray auto, sold
63 230SL Metallic Blue manual, sold
Reply #7 on:
April 15, 2009, 00:16:25 »
I heard Joe A. mention this a few years ago and I have done this ever since....
After washing and drying the car, I go for a drive to do a final "blow dry". This really helps to dry out all of the nooks and crannies...
Thanks Joe!
Ulf
Associate Member
Gold
Reply #8 on:
April 15, 2009, 10:58:31 »
Thanks - I'll go with Sponge Bobs' suggestion...
Ulf
2008 Jaguar XF 3.0
2005 Mini Cooper
Hood/Bonnet seal
