Author Topic: anyone have a good source for Oil coolers, rebuilders  (Read 6369 times)
olaf
« on: April 16, 2009, 02:08:15 »
the oil cooler in My 1970 280 SL is rusty and leaking.
Does anyone have a good source that can rebuild the core or where to purchase new or used?
franjo_66
  • Australia, NSW, Point Piper
Re: anyone have a good source for Oil coolers, rebuilders
« Reply #1 on: April 16, 2009, 04:10:38 »
hi Olaf
Millers Benz (www.millersbnz.com) has the 280SL oil cooler listed at $978.50
However Adsitco (http://www.adsitco.com/category.asp?CID=977) has the same oil cooler listed for $355.50 !!  That is quite a price difference.
Rgds
Frank
Franjo
1965 230SL Black/Auto/RHD
2005 Porsche Cayenne Turbo
1983 BMW 735i
1986 560 SEC
1991 500SL
1982 Holden Statesman DeVille
« Reply #2 on: April 16, 2009, 11:07:53 »
The original oil coolers on these cars are steel and are brazed together. This heavy duty construction is needed for the high pressures the system carries especially when the oil is cold.  Rust causes leaks in the steel cores and weakens many other areas with pits.  I do no know of anyone making good lasting repairs on these.
The oil coolers on the W108 4.5 sedans are all aluminum construction and are the same size.  However they are on the opposit side of the radiator, but it looks like they could work. Has anyone tried these?  They do not have the rust problem.
« Last Edit: April 16, 2009, 22:07:44 by ja17 »
« Reply #3 on: April 16, 2009, 12:06:36 »
The oil coolers on the W108 4.5 sedans is all aluminum construction and is the same size.  However they are on the opposit side of the radiator, but it looks like they could work. Has anyone tried these?  They do not have the rust problem.
Yes, there was one of these aluminum ones from a 107 that one of the guys at the last PUB at Blacklick was trying to sell. Looked like it would do the job - only the drain plug would end up at the top but the bottom line could always be used for draining it.
Also look at one from an early W114.
The end is  mounted with large O rings but once you take the rubber strips off, they are the same as the 113s. The only thing missing is the 2 captive nuts that bolt it to the 113 body. The holes are already drilled though. You could probably use appropriate 'nutserts' to do the job.
« Reply #4 on: April 16, 2009, 12:59:28 »
Can someone with a 280sl/auto post measurements of the oil cooler? I have one from a 108 sedan, but not sure if it will work (it seems too tall...)
« Reply #5 on: April 16, 2009, 13:26:48 »
Waqas,
The part # is stamped on the side where the bolts (to the body) go.
Shud be 108 180 0165 or 0265 if its a later one.
« Reply #6 on: April 16, 2009, 14:46:42 »
Thanks Naj!  I'll go check it out...
« Reply #7 on: April 16, 2009, 22:06:34 »
Now, the six cylinder W108 (280 series with M130 engines carbureted or injected) sedans have exactly the same oil cooler. Same part number and I believe the W113 cars have a 108 part number. Only the v-8s have the aluminum cooler on the oposite side.
Yes,  many of the W114 cars had a very similar steel cooler, different mounting and no drain plug on these versions.
« Last Edit: April 16, 2009, 22:09:45 by ja17 »
merrill
« Reply #8 on: April 17, 2009, 01:13:59 »
This may sound strange, but find a radiator re builder and give them a call.
often they can take measurements and order a new core for you.
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
« Reply #9 on: April 17, 2009, 03:25:47 »
Hello Merrill,
I would be interested in knowing of a radiator rebuilder who can replace steel cores which are brass welded together into these units. This is quite a bit different from the standard soldered together copper radiators used in coolant systems.
