Author Topic: Wiring diagram - 1970 280 SL US version  (Read 12770 times)
lgr
« on: April 24, 2009, 19:17:47 »
Hellow everybody!
I'm looking for the wiring diagram for my car and I only can find one on the technical manual of this site, but I don't know if that one is for a US version and no legend is shown there!
Can anyone help me on this?
Thank you in advance for your comments
Luis Gama Rocha ( from sunny Portugal!!)
Re: Wiring diagram - 1970 280 SL US version
« Reply #1 on: April 24, 2009, 20:46:25 »
Here is a diagram for a 280SL from 1970 for the standard (Euro?) cars.
[removed] Use link in the next msg
The size can be enlarged by clicking on the diagram image.
I have not seen a wiring diagram especially for US Version cars.
Richard M, NYC
« Last Edit: April 25, 2009, 00:03:30 by 280SL71 »
« Reply #2 on: April 24, 2009, 22:34:35 »
The legend is here: http://www.sl113.org/wiki/Electrical/WiringDiagram
Do not use the link that Richard provides as it links directly to the diagram only. Always use the link above instead! It also links to the Connectors Section.
We do not have wiring diagrams specifically for the US, so the emissions control stuff is not on there... if someone has that on a diagram, mail me and we'll put it up.
Anfinn
« Reply #3 on: April 25, 2009, 09:19:59 »
I have the Service Manual Library Volume 4 (2 CD set) from MB USA. (Edit: It is now also to be found in the Tech Manual)
This contains a better diagram for the late 280SL, US-version with Automatic.
The additional components for the auto are shown, also the correct setup for Haz. warning flasher, and transistor ignition.
« Last Edit: May 22, 2009, 19:07:15 by Anfinn »
thegivingway
« Reply #4 on: May 20, 2009, 18:50:10 »
Need some help with a 69 Euro 280SL that I had apart.  My electrical connectors are missing and I need to figure out which terminals each wire goes on.  Checking the connector diagram in the technical section yielded a chart stating - 'All Models Except 280SL'.  Where can I find the 280SL connector chart?  Need to know which wires go on the middle (of three) relay on the drivers side and the lock out / reverse switch mounted on the firewall.  If the connector diagram is not available can someone check on there car?
« Reply #5 on: May 20, 2009, 21:22:26 »
You'll find that 98% of the connectors listed in said document are also valid for a 280SL. Mercedes-Benz didn't change much if they didn't need to.
thegivingway
« Reply #6 on: May 21, 2009, 01:47:26 »
The number of terminals was different on one and the other connector wasn't listed at all.
« Reply #7 on: May 21, 2009, 08:07:34 »
Sorry, it's in the 2% then...  :-[
thegivingway
« Reply #8 on: May 21, 2009, 13:22:45 »
Here are the pictures of the two places I need help with the wiring.  If someone can take a look on your car and let me know which wires go to which terminals, that would be awesome.
« Reply #9 on: May 22, 2009, 08:09:48 »
Here's what's on my car (1970 280SL US Version, emissions stuff removed). You'll notive I have a different firewall switch. However, of the 6 pins only the four closest to the actuator are wired (see pictures). I've taken a photograph with the plug connected so that you can see where they go. Be careful when wiring up your socket, as it's easy to do it the wrong way round.
The relay plug is wired as shown... Now let's hope the wire colours match up!
« Last Edit: May 22, 2009, 08:12:30 by vanesp »
thegivingway
« Reply #10 on: May 22, 2009, 18:14:41 »
Perfect!  One problem solved - thank you very much for the photos.
