Author Topic: Idle speed  (Read 4833 times)
jmvsl
Idle speed
« on: April 29, 2009, 18:41:05 »
What should be the correct settings for the idle speed for a 230SL on cold and warm engine temp?  please advice thanks.
glenn
Re: Idle speed
« Reply #1 on: April 30, 2009, 09:06:09 »
800 rpm.
Re: Idle speed
« Reply #2 on: April 30, 2009, 10:36:11 »
Not sure about a 230, but a 280 runs at about 1000 or 1100 rpm when cold then drops to about 800 as it warms up. In some cars, the rpm can vary in stop-and-go traffic between these two numbers, not sure why.
The idle speed can be changed (if all else is properly adjusted) by turning the air intake control knob (not its official name) on the right side of the engine.
Richard M, NYC
Re: Idle speed
« Reply #3 on: May 04, 2009, 23:01:07 »
Yes ,  the warm idle is usually around 750 - 800 rpms and the cold idle can be as high as 1100 for a short time.
