Author Topic: what gear oil to use to bring the whine down a little 80-90 or 75-140?  (Read 4963 times)
erickmarciano
  • Canada, Quebec, montreal
just adjusted the rotation force on the rear diff from 12 lbs to 16lbs and the diff now makes less noise . would the type of gear oil affect the noise? is so what to use to minimize the noise?
thanks
1994 E500 W124
1971 280sl
1989 Porsche 930 coupe
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
awolff280sl
  • USA, FL, Sarasota
Before I tightened my diff drag, I had a definite whine betwen 45-60mph. After tightening it is barely perceptable and I can only hear it between 55-60mph with acceleration. I'm using Redline synthetic 75-90, don't know if it makes a difference.
Andy   Sarasota, FL
'69 280SL 4speed
'06 Mitsubishi Evo
erickmarciano
thanks for all your past help ,the job was very easy with the right tools.my noise is only barely noticible at the same speed as you. hope I did not tighten it to much .
to all the others do you think synthetic would lower the noise even more?
thanks
1994 E500 W124
1971 280sl
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
jameshoward
Erik,
Can you define 'really easy' and 'the right tools'? I am about to attempt with another the replacement of my rear axle and will want to give it the once over beforehand.
Is the process one that is easily described?
James Howard
1966 LHD 230SL
James,
Did I read that right, you are about to take out the 3.46 axle and replace it with another??
1972 MB 280CE Auto RHD 906G
2022 Volvo XC40 Electric
2024 Volvo EX30 Electric
erickmarciano
1994 E500 W124
1971 280sl
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
