Author Topic: does anyone know where in the seat this part goes?  (Read 3202 times)
erickmarciano
  • Canada, Quebec, montreal
« on: May 07, 2009, 03:36:20 »
my late 280sl has a 3 prong part to move the backrest up or down and the only part I find in the EPC is this ?is this the replacement part for the 3 prong adjuster?
click on # 34 in this link and you will see the part
http://www.sls-hh-shop.de/index.php/cat/c3_Mercedes-Benz-230-280SL--R113-.html#cat_98_position_34_prod_0
thanks
1994 E500 W124
1971 280sl
1989 Porsche 930 coupe
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
Tom Colitt
Re: does anyone know where in the seat this part goes?
« Reply #1 on: July 25, 2009, 18:59:16 »
Good question. The original part is a one piece design, I believe. You might have to get this piece and the threaded rod, new...
zoegrlh
  • USA, VA, Williamsburg
  • Beauty from top BCW
« Reply #2 on: August 04, 2009, 12:16:33 »
No, the part #34 is a "roller", there are two for each seat.  I think what you are looking for is the shaft #32. On the end of the shaft are three prongs that is made part of the shaft, that when shaft is turned with the tilt knob #35, climbs a cog device that is spring (#45) loaded.  This cog device is attached to  part number 30 ("l" shaped frame).  You need the shaft part.
Robert Hyatt
Williamsburg, VA.
