Author Topic: special tool for switch removals  (Read 5275 times)
rmmchl
  • USA, WV, Charleston
« on: May 12, 2009, 01:23:03 »
what type tool is used to remove and tighten the emergency switch crome grommett?
michael romeo
1967  250sl
signal red
Re: special tool for switch removals
« Reply #1 on: May 12, 2009, 02:32:41 »
I'm sure Mercedes has a special tool, but I've used a set of lock-ring pliers with some success. There chrome rings are never supposed to that tight anyhow...
scoot
  • USA, CA, Altadena
« Reply #2 on: May 12, 2009, 16:14:32 »
There is a guy on ebay who periodically sells a "special socket" for removing the bezels of the switches.  The problem is that most of the bezels are different, and the socket he sells doesn't fit over the ones that have knobs attached, like the fan knob for instance.  I sent mine back.  I use snap ring plyers and do it carefully.
Scott Allen
'67 250 SL (early)
Altadena, California
ejboyd5
  • Southold, NY
« Reply #3 on: May 12, 2009, 16:43:18 »
Make your own from a wire coat hanger - take a 10" to 12" section, bend to a "U" shape, then place in a vise and turn the very end of each leg at ninety degrees toward the other leg.  File the end of each ninety degree "pin" that you just made to the appropriate length to fit the hole in the escutchon and you have a tool which will last you for many years.
rmmchl
« Reply #4 on: May 12, 2009, 21:49:00 »
the coat hanger is also a very good idea
michael romeo
1967  250sl
signal red
