Please check out joining the
Emergency Contact List
for help during your travels!
strange engine nosie
Topic: strange engine nosie (Read 4295 times)
xcashewx
May 18, 2009, 04:22:20 »
the noise sounds like screeching metal, but the thing is it only occurs when the car is fully warm and the accelorator is pressed to th floor? my guess when driving was the FI pump... any ideas?
Associate Member
Platinum
United Kingdom, Surrey, New Malden
Re: strange engine nosie
May 18, 2009, 08:02:12 »
Loose fan belt?
menesesjesse
Full Member
Silver
USA, MD, Indian Head
Reply #2 on:
May 18, 2009, 14:41:16 »
If you remove the belts and run the car you should be able to rule out the belts and pulleys off the accessories. Dont run it long because youll have no water pump, alternator or P/S availiable. This is done just as a test. Good luck and please keep us posted.
Jesse
Jesse
1966 Mercedes 230 SL auto
2003 Mercedes E500
1992 Ford F150
1994 Ford Bronco
2019 Shelby GT350R
1967 Mercury Cougar XR7
Full Member
Platinum
USA, CA, Fallbrook
Reply #3 on:
May 18, 2009, 22:23:19 »
fan (engaged when engine warm, viscous coupling driven) hitting 'something' up front?
xcashewx
Reply #4 on:
May 19, 2009, 04:47:19 »
i checked to see if the fan was hitting but its not, when its warm it will only make the noise with full thottle if i ease into the gas to full position it is still there but not nearly as loud??? :/
JimVillers
Full Member
Gold
USA, VA, Virginia Beach
Reply #5 on:
May 19, 2009, 12:21:10 »
I assume that you are driving the car when you hear this noise. If so, check your engine mounts as at full throttle, the engine will tend to twist and possibly something might rub (like the drive shaft if the rear mounts are collapsed).
Jim Villers
