with our official
Pagoda SL Group logo
from our official partner.
csv on 1965 230sl
Topic: csv on 1965 230sl (Read 3917 times)
markh
csv on 1965 230sl
May 19, 2009, 12:07:20 »
checked out csv and found it not spraying fuel removed from car and after examining valve found the black rubber insert all swallen and split i am in england could anyone tell me if there is a repair kit for these or anyone that recon them many thanks mark
Associate Member
Platinum
United Kingdom, Surrey, New Malden
Re: csv on 1965 230sl
May 19, 2009, 13:19:47 »
Hello, Mark,
There is a small 'O' ring between the solenoid and needle valve and a bigger 'O' ring between the valve assembly and inlet manifold. Are you talking about one of these?
They are available separately from MB.
markh
Reply #2 on:
May 19, 2009, 14:24:51 »
hi no its not the o rings i have removed the solenoid off the csv and there is a rubber insert about 1 cm long which is pushed in the valve have called mb here and there saying no repair kit so what now regards mark h
Associate Member
Platinum
Reply #3 on:
May 19, 2009, 14:31:38 »
Hello, Mark,
Besides the 2 O rings, there are no other rubber parts in the csv.
Have a look in the wiki:
http://www.sl113.org/wiki/Engine/ColdStartValve
markh
Reply #4 on:
May 19, 2009, 15:36:26 »
hi naj just looked at csv tec sheet and it does not show this insert but honest i have taken thie rubber sleeve out it sits where the small o ring should be but fits down the hole where solenoid needle lives confused i am regards marh
Associate Member
Platinum
Reply #5 on:
May 19, 2009, 18:19:28 »
Maybe the PO did a mod
csv on 1965 230sl
