I got this car with the glove box retainer spring(s) missing. The only way to keep it closed is to keep it locked. Whoever jury-rigged this (some time ago) drilled a small hole in the left side of the glove box and turned a screw in, to hold the box body up about 1 cm higher than it should be. This causes the curved rod attached toi the glove box door to stop on the dash board - which prevents the door from opening beyond 90 degrees. This is ok, but when the glove box door is closed (and locked to stay closed), the left had side of the dorr does not aligh with the rest of the dash, it's up about 1 cm - which is most annoying.
Now, since I've never seen what the spring or springs look like, I can't figure out how fabricate the whatever should be there so the glove box door works like it should.
Can anyone give me a good descrition of how the spring(s) mount and how they work? Are these springs (and whatever other necessary hardware) still available for purchase through MB?
TIA :-)
