Author Topic: Charging Current Light - Red  (Read 4229 times)
Via Manci
« on: May 24, 2009, 21:12:24 »
Should this light be on during idle and when driving ???
graphic66
Re: Charging Current Light - Red
« Reply #1 on: May 24, 2009, 22:43:35 »
Nope, you aren't charging. Your battery is going to go dead at some point. Bad alternator or regulator or wiring.
auret
« Reply #2 on: June 03, 2009, 17:03:07 »
Are you sure it is the charging light. The one right next to it indicates open door or low brake fluid.
« Reply #3 on: June 03, 2009, 21:03:41 »
So if he won't go, it's a battery issue, and if he won't stop it's a brake issue. :o :o :o
