Author Topic: Wheel bearing  (Read 3583 times)
bbryant
Wheel bearing
« on: June 08, 2009, 21:36:13 »
What holds the rear wheel rotor on a 280SL? Is it held on by the caliper ?
Re: Wheel bearing
« Reply #1 on: June 08, 2009, 22:51:21 »
The wheel lug bolts hold the drumi on tight .  The caliper is in the way and must be removed so that the disc can be removed. The caliper can just be unbolted without dis-connecting the brake line.
Note the small "peg" coming out of the axle hub, it is used to index the drum duming re`-assembly.  Make sure the emergency brake is released or it will hold the drum on. !
bbryant
Re: Wheel bearing
« Reply #2 on: June 09, 2009, 11:37:42 »
Thanks Joe.
