Author Topic: Fuel Filter part numbers  (Read 3966 times)
paults1
  • USA, FL, The Villages
« on: June 10, 2009, 01:40:24 »
I just received a fuel filter from Bud's Benz.  The filter is a Mann part no. BFU 707. Can this be used instead of the Mann P707?
Regards, Paul '63 230SL
Re: Fuel Filter part numbers
« Reply #1 on: June 10, 2009, 10:13:37 »
I think YES.
The P707 is a paper filter and usually used for 'petrol'
The BFU 707 is a diesel filter with white cloth-like filtering element.
I think the latter is a finer filter and I have used them before. When I first got my car, MB supplied me with a similar filter but not MANN.
« Reply #2 on: June 11, 2009, 04:36:22 »
I have seen these switched around without consequence.  They are exactly the same size.  I always use the gasoline one since I do not know the flow rates of the two. The upper and lower  filter seal rings on the two are  different. The gasoline has felt seals, the diesel had  rubber-like seal rings. It would be interesting to hear what the manufacturers take on this is.
« Last Edit: June 12, 2009, 04:47:42 by ja17 »
