Author Topic: Wheel bearing lock washer  (Read 5535 times)
bbryant
« on: June 10, 2009, 19:11:51 »
I am replacing the left wheel bearing on my 1970 280SL. In doing so I need to replace the Lock plate as referred to in the technical manual. This is a washer with tabs that when bent up prevent the "grooved" nut from spinning.
I have found bearing kits from several vendors, however none contain this lock washer.
Does anyone know a vehicle which also has an identical lock washer or where I can order this part?
Many thanks.
Re: Wheel bearing lock washer
« Reply #1 on: June 10, 2009, 21:55:55 »
I got complete bearing kits from the classic center a while back. They included the locks.
Perhaps they can supply the individual parts that comprise the kits.
Still haven't gotten around to doing this job....
bbryant
« Reply #2 on: June 16, 2009, 00:12:18 »
I ordered and received the wheel bearing kit but the lock washer doesnt have the bend up tabs, has Mercedes done away with this type washer ?
JimVillers
  • USA, VA, Virginia Beach
« Reply #3 on: June 16, 2009, 00:37:49 »
I have reused the lock tab.  If you turn it 180 degrees, you should have a fresh tab to bend up.
Jim Villers
auret
« Reply #4 on: June 16, 2009, 05:49:30 »
I recently rebuilt my rear axle including replacing the bearings and lock washers. I got the lock washers from K & K Mnfg. They are flat and do not have tabs to fold up. Once tightened I used a punch and a hammer to bend/knock part of the washer up into the groove.
« Reply #5 on: June 16, 2009, 21:14:59 »
I did what Auret describes when I replaced my rear bearings about 6 months ago. Not exactly a clean result, but an effective one and that's what counts.
bbryant
« Reply #6 on: June 17, 2009, 01:30:52 »
thanks to all, it turns out the lockplate is flat and is now designed to punch up at the appropriate grooved slots on the nut
