Author Topic: Window Crank Removal  (Read 3507 times)
rb6667
« on: June 11, 2009, 12:06:48 »
How do you remove the interior window handles on a 280SL ?
Thanks very much,
RB6667
Re: Window Crank Removal
« Reply #1 on: June 11, 2009, 13:46:59 »
If you pop off the plastic insert, the rest will become obvious. I know of two ways they are attached: either a screw or else a spline without a screw. Again, you will see this.
I dug up this which might help a little: (I had to adapt a crank to match my other one on my 230SL)...
« Last Edit: June 11, 2009, 14:05:09 by J. Huber »
« Reply #2 on: June 11, 2009, 18:34:06 »
Notice the elongated hole in the pad of the 280 handle.
The shaft has a groove into which the narrow bit engages to hold it in place.
Push the pad down so that it disengages from the groove to the larger diameter hole.
This allows you to pull the handle away from the shaft.
rb6667
« Reply #3 on: June 13, 2009, 00:45:11 »
Thanks for the pictures James.  That will help a lot.  Naj. I appreciate your comments as well.
RB6667
