Author Topic: How to Re-Chrome the Rear Light  (Read 3531 times)
montearena
« on: June 18, 2009, 21:34:07 »
I will chroming various parts of my 230sl/1966
Somebody know How can I remove the chrome part ( frame ) of the rear light.
« Last Edit: June 21, 2009, 10:03:22 by 280SL71 »
montearena
Re: how I can re-chrome the rear light
« Reply #1 on: June 20, 2009, 21:55:57 »
How It is possible to separate the chrome of the red part, to send it to re-chroming
« Last Edit: June 21, 2009, 10:46:14 by vanesp »
DaveB
Re: How to Re-Chrome the Rear Light
« Reply #2 on: June 21, 2009, 13:13:54 »
These early tail lights are one-piece units and are not designed to come apart. You could perhaps carefully cut and grind them out, but as I'm sure you've observed, it won't be easy. Maybe someone else has tried it and can advise.
Regards, David
DaveB
'65 US 230sl 4-speed, DB190
« Reply #3 on: June 25, 2009, 19:35:15 »
Dave is right.
You have to cut or grind the lenses carefully out (from inside!!) and glue them back with epoxy or something else like that after rechroming the frame.
It's not straight forward but can be done.
Remove the rubber gasket first (if you are careful, you can even reuse it), then you will realise how to "pop" out the mirror.
After that you will find that the lens is casted into the frame outside in. You need to cut the inner lip away until you can carefully press out the lens outwards.
Good luck!
