Author Topic: Daylight  (Read 3183 times)
Daylight
« on: June 21, 2009, 15:09:07 »
I was having a little dust out in the boot (trunk) this afternoon and wiped down the left rear wheel arch (inside the trunk). My aerial is mounted above this.
Anyhoo, as I came off the arch onto the trunk floor under the mat, what should I spy but... daylight. MMMmm, not good methinks. This is right where the arch hits the trunk floor AND outer side panel. In the picture it's just below the rust and you can just see the "topside" of the inner wheel arch
It seems to be coming from behind the inner/outer arches and so is not taking roadspray directly up under my mat. But.... I am guessing that a hole is not the best thing to have. And how do I best close it?
