Author Topic: which cables go where?---tach /speedo/ oil pressure/temp  (Read 3321 times)
rmmchl
  • USA, WV, Charleston
does anyone have a picture of the wirewall that shows what cables go through which 2 holes-----I took all my guages out for servicing and painting das--I should have taken a picture or written it down--------the tach cable, temp sensor wire, speedo cable and oil pressure-which 2 go inot the upper hole, and which go inot the lower hole in the firewall?
michael romeo
1967  250sl
signal red
Re: which cables go where?---tach /speedo/ oil pressure/temp
« Reply #1 on: June 22, 2009, 23:25:40 »
Tach-Temp on Top. Grommets are cheap and available.
