Author Topic: Oil/water heat exchanger availability  (Read 5262 times)
« on: June 25, 2009, 01:13:13 »
Does anyone know if the oil/water heat exchanger that came installed as standard on all fuel-injected M-129 engines (250SL, 250SE, etc) also came installed on the carb version? (250S)
Re: Oil/water heat exchanger availability
« Reply #1 on: June 25, 2009, 13:10:17 »
Don't know but Will Samples has one on his ebay sale:
The Ebay item # is 130314254944
« Reply #2 on: June 25, 2009, 14:23:29 »
Thanks Naj!  (I've placed a bid)
DaveB
« Reply #3 on: June 26, 2009, 01:23:17 »
Yes they're also on the 250S.
DaveB
'65 US 230sl 4-speed, DB190
« Reply #4 on: June 26, 2009, 05:17:38 »
I've seen them on 230SL's as well. Quite rare but they did install them as an option. I think I still have a few of those exchangers around here.
Dave Gallon
  • USA, NC, Statesville
« Reply #5 on: July 02, 2009, 19:41:28 »
Only going by the 230SL (edition C) parts book, it appears the oil/water heat exchanger was installed originally on all 230SLs. I have never owned a 230 and make no statement from experience.
Dave Gallon
Gallon Restorations
113.044-12-001155
« Reply #6 on: July 02, 2009, 20:55:21 »
I don't believe that all 230SL were delivered with the oil heat exchanger. It is not shown in Spare Parts List Edition A (July 1963) but does show up in Edition C (Group 18 p/n 000 188 44 01). However, my 230SL (Aug. 1966) did not come with it. Most likely an option for the late 230SL as Dan pointed out.
« Last Edit: July 03, 2009, 01:07:46 by 66andBlue »
« Reply #7 on: July 03, 2009, 00:07:53 »
Alfred is correct: the heat exchanger was optional on the M127-II engine, but came standard on all M129 engines. By the time the M130 came along, there was an oil cooler next to the radiator.
(A recent post by ja17 also confirmed that the heat exchanger was standard in the 250S)
