Author Topic: 123 ignition distributor?  (Read 5877 times)
« on: June 26, 2009, 04:41:11 »
does anyone now or have on their SL  a 123 ignition Distributor? I own a 1968 280SL and want to set  up my car for road use and reliability. I have the later aluminum Bosch single point distributor. how does this 123 distributor compare to the Partronics kit. I am not looking at price but real time use with  both systems.
I now this may be an apple and oranges comparison. but any feed back would be appreciate.
Bob  Geco
Re: 123 ignition distributor?
« Reply #1 on: June 26, 2009, 08:01:18 »
where have you been? The 123 distributor has been discussed very extensively and in great detail in this thread: http://www.sl113.org/forums/index.php?topic=9984.0
Bob Possel did a lot of research on them for his car. In the Technical Manual a summary is given.
Pretty much everyone who has one is very happy with it.
« Reply #2 on: June 26, 2009, 09:53:47 »
Hi Bob G. !
The 123 has been working great for me.  I have used both the 123 and Pertronix.  I replaced my Pertronix, along with my distributor, with a 123 unit because my distributor was worn and not repairable.  The Pertronix setup works well with a good distributor.
Hope this helps.
bob
« Reply #3 on: June 30, 2009, 05:45:56 »
Peter.
I move slow these days still have pain in my legs from my back surgery. I got call as I explained to Bob from the sales representive  I posted the inquiry to makesure it was leglite.
See you in black lick Ohio.
bob & Sharon Geco
scp
« Reply #4 on: July 07, 2009, 12:34:30 »
Perhaps a bit off topic, but how does one remove the old distributor?  I have loosened the clamp and the distributor is frozen in place - it does not move at all (can not change timing).  Is there a degree of "persuasion" that could be used (beat on it with a hammer) or is it worth taking the distributor bearing body off the engine and bringing the whole thing to a machine shop?  Has anyone encountered this before?  Any suggestion would be appreciated.  Thanks.
-SCP
jameshoward
« Reply #5 on: July 07, 2009, 18:31:23 »
You could try some penetrating oil at the collar of the distributor applied over a few days, but it may be that after lack of use the collar is a bit stuck, so you may not have fully slackened it. The housing is aluminium, and the dissy (probably) steel, so you could try a little heat on the collar gently, but note that there are petrol lines around there also, so don't use an indescriminate naked flame. I would expend some effort with penetrating oil and attempting to move it back and forth before removing the entire housing. I think you'll find it will move with a little preparation.
Apparently a 50/50 mix of ATF and acetone makes the best penetrating oil. I've also had success with old brake fluid (which I think JA recommended).
(Don't beat on it with a hammer, tho).
JH
James Howard
1966 LHD 230SL
