Author Topic: Breather pipe source  (Read 3820 times)
seattle_Jerry
« on: June 28, 2009, 00:18:00 »
Any suggestions on where to find a replacement metal breather pipe? As I work through the engine I just noticed that it is broken and held together by tape.
Re: Breather pipe source
« Reply #1 on: June 28, 2009, 03:00:42 »
Hi Jerry. As far as I know, the original all-metal breather pipe is NLA. The replacement ones (they are now rubber) are available from SLS, Miller's, etc I believe. How far gone is yours? The original was two metal pipes joined by a coolant hose. Mine was corroded a bit near the tips but I was able to salvage it.
seattle_Jerry
« Reply #2 on: June 28, 2009, 23:14:30 »
My break looks just like yours except its right next to that clamp. I like the banjo bolt setup better than the rubber elbow mine has, btw
jacovdw
« Reply #3 on: June 29, 2009, 09:33:27 »
Hello Jerry,
I had my metal breather pipe rebuilt a couple of years ago by a reputable hydraulic pipe specialist.
I gave them the original rusted pipes to use as a template with the instruction to retain the original banjo bolt fitting.
They did a very good job of bending similar diameter metal pipes to match the shape of the original design.
The original banjo fitting was soldered back in place.
