Author Topic: left blinker flashing rapidly  (Read 4258 times)
rmmchl
  • USA, WV, Charleston
« on: June 30, 2009, 01:49:53 »
just got my ccenter cluster back from north hollywood speedo-I had a new temp wire  and all the bulbs changed-------------the left flasher flashing real fast....Does anyone know what they could have done?-I'll call them tomorrow--------Also, I dont think there is a brown ground wire for the cluster-Am I correct on this?--------There is one for the tach and speedo-I didnt see one for the center cluster
michael romeo
1967  250sl
signal red
awolff280sl
  • USA, FL, Sarasota
Re: left blinker flashing rapidly
« Reply #1 on: June 30, 2009, 01:59:15 »
Check your tail lights. One of the bulbs may be loose or blown.
Andy   Sarasota, FL
'69 280SL 4speed
'06 Mitsubishi Evo
rmmchl
« Reply #2 on: June 30, 2009, 02:32:53 »
awolf-you maybe onto something----the left fron light that is supposed to flash isn't working-the one under the amber part of the housing-the rear is blinking----The bulb doesnt look burned out, but i will test it-the number is worn off.....anyone know the correct bulb for this?
michael romeo
1967  250sl
signal red
rmmchl
« Reply #3 on: June 30, 2009, 03:01:42 »
i found it---------------corrosion-cleaned up the housing at it worked--do they make a cleaner to spray on the bulbs -and contact points to clean up , and prevent and remove corrosion
michael romeo
1967  250sl
signal red
ejboyd5
  • Southold, NY
« Reply #4 on: June 30, 2009, 19:47:59 »
Try Corrosion-X, you will not be disappointed.
