Author Topic: Door rattle  (Read 3150 times)
flacc
Door rattle
« on: July 02, 2009, 22:07:46 »
My car has developed a door rattle on the drivers side on very irregular occasions.  I'm fairly certain it's not the window glides as if I hold the door down it stops the rattle.  A buddy suggested it must be the striker plate (part # 72-2030).  He said they can get worn.  There is a rubber gasket inside into which a metal pin from the door slides.  Has anyone experienced this problem and perhaps this simple fix?  The part is (of course) not cheap so I hate to order it without some input from the respected wizards here.
psmith
Re: Door rattle
« Reply #1 on: July 07, 2009, 19:18:09 »
Check the screw hiding under the armrest that helps hold the door panel to the door.
Re: Door rattle
« Reply #2 on: July 07, 2009, 20:05:58 »
flacc,
Does this happen with the window up or down or doesn't it matter?
On my car, the bottom of the window mechanism was touching the bottom of the door--or darn close to it.  Going over a bump or rough pavement made a metal on metal contact.  A window adjustment, and some cushion on the bottom of the door solved the issue.
Try isolating precisely when the rattle occurs and the conditions that may exist.
