Author Topic: IP Oil level - measuring??  (Read 3436 times)
rogerh113
  • Los Altos, Ca
« on: July 03, 2009, 22:15:10 »
Is the Injection Pump oil level measured at the 'inserted' or 'screwed in' level??   The screw threads are about a half inch, and it makes a big difference if they are counted or not -  the current level is good if measured screwed in, or low if just measured at inserted level.
Regards -- Roger
jameshoward
Re: IP Oil level - measuring??
« Reply #1 on: July 03, 2009, 22:53:03 »
Screwed in level is the measurement to use.
James Howard
1966 LHD 230SL
rogerh113
  • Los Altos, Ca
« Reply #2 on: July 04, 2009, 00:13:30 »
Thanks - then it looks like the level is OK.
Regards -- Roger
