Author Topic: Major disaster - need advice  (Read 15108 times)
glenn
Re: Major disaster - need advice
« Reply #25 on: July 20, 2009, 17:27:35 »
If you do the 'drill out' option, bolt a 1/2" plate down with a 2 MM or so hole centered on the bad bolt.  This will keep the drill bit from walking.  Next a 3 MM, next a 4 MM, etc,    Hand file if it's off center a little.  Last drill is the bit for a 6 MM tap.  Then tap it out.  These bolts don't have much loading -hopefully.
glenn
« Reply #26 on: July 20, 2009, 17:38:21 »
TIG???   Thousands In Gold???
