Author Topic: No man cave, but...  (Read 19358 times)
No man cave, but...
« on: July 13, 2009, 15:43:46 »
Well, I have no man-cave like many, and it is unlikely I'll ever have any garage even approaching the beauty that is thelews (see his photos) or many of you.
But after nearly 20 years in Michigan, I'm tired of snowblowers and shovels.  Tomorrow, barring unforseen circumstances, they are pouring my new driveway.  That in and unto itself isn't much worthy of a topic, but the nearly 2100 feet of heating tubes are.
Something I took away from the car wash business.  Tubes were installed last week, have been under pressure test since Thursday, and we're all set for concrete tomorrow.
No more snowblowers, no more shovels.  The snow will not even stick to it...yes, a snow-melt driveway.
Of course El Nino is blowing which means we won't have a wild winter, but I'm ready nonetheless. ;)
  • USA, WI, Mequon
Re: No man cave, but...
« Reply #1 on: July 13, 2009, 16:21:32 »
Thanks for the compliment.
What will the driveway cost to heat?  Can it keep up with a serious snowstorm like 12 inches?  They don't allow it here.
« Reply #2 on: July 13, 2009, 17:15:36 »
John,
I had a de-icing system at the car wash.  I added on to the heated area but not to the boiler capacity in 2003.  In the area I added to, I did it by modern standards with insulation under the concrete.  I can tell you with certainty that when the system was "on", no snow accumulated on the added section, regardless of storm; no ice formed either.  It was almost as if that slab was in a different world.
The difference between a de-icing system at a car wash and a residential snow melt system is notable.  The de-icing system must operate to prevent the formation of ice down to the design point; in our climate, it's about -10F.  It turns on at about 35, and cranks more and more heat into the system as the outside temp drops.  At a car wash, it is on based solely on temperature because water is flowing all the time, and if it wasn't on, you'd freeze quickly.  You don't need as many BTU's on a snow melt as you do on a de-icing system.
A residential snow melt operates a bit differently using the same hardware.  You turn it on in anticipation of precipitation either snow, sleet or freezing rain.  These three nasties, believe it or not, generally fall between a narrow band of temperature.  Much below 25 or 20 degrees, we often don't have any precipitation falling (perhaps in Northern Canada or Antarctica, but not often here).  Above 35, it's rain.  Once the precipitation has stopped, you turn it off.
So, we have a few snowfalls in January, you turn it on.  When we have days or weeks of freezing weather, but no precipitation, it sits there.  No cost to run a system that isn't on.
I'll have good info on cost to run once it is all running.  I even bought a gas "sub-meter" so I can measure the gas used by the heater for this system, which is a 140,000 BTU tankless water heater.  If it were a de-icing system, I'd have to go to 190,000 BTU.
Why have I done this?  It takes me about 90 minutes to clear my driveway after 4" of snow.  Those 1" falls are even more annoying--too little for the snowblower.  The big snowfalls--6" or 8" or more, generally take two or more passes.  If I contract it out, it can be $350-$450 per season; and they come when they get to you, not when you want to get out.  Some roving guys--if you catch them, will do it for $25 per push.  No matter how you deal with snow, it costs money; it takes time.  Nobody ever had a heart attack (not that I'm planning on one!) turning on a snow-melt system.  You can burn gasoline in a show blower; you can pay someone to do it with a plow, burning gas or diesel.  You can spread up-teen pounds of corrosive salt or calcium chloride to help you in your cause, at a cost of $5 to $25 a bag.  Winter 2007/2008 there was a feigned shortage of salt and de-icing compounds so the price skyrocketed and availability was non-existent.  The space I have to clear is simply too large to do it by hand, you need energy-consuming tools.  A snow melt system built in is simply another energy consuming tool.  So until I move to the Southwest...
There will be a non trivial operating cost.  I don't believe some [equipment vendors] who say $100 per season.  I also think that those who have them and shut them down because of cost to run might not have had them designed or fired properly.  We'll see.  I worked with my car wash supplier who has installed hundreds of these and repaired plenty, too.  They know more about this stuff than any heating contractor, simply because of decades of real-world operational and installation experience.  Most heating contractors know almost nothing about radiant systems for this application.  There will certainly be some tuning and learning involved.  We have designed balancing systems into it so we can tune the system based on operational characteristics, not theoretical design.  Factors such as where the sun falls on the driveway and when make a big difference in how it all works.  We're prepared for tuning it.
How can your municipality tell you you can't have a snow melt driveway?  Is it the gas consumption?  Are they in the gas business?  What if you had a geothermal-fired system?  Or solar?  Or wood fired?  There are all kinds of ways of making the heat needed for this.  I have 5/8" tubing, 1 linear foot per square foot of driveway, done in 7 zones/loops generally around 300' each.  It is tied to 6 x 6 steel mesh; it sits on 1 1/4" insulation on top of 5" of pea stone base.  The concrete is 5" of 6-sack, fiber reinforced, 4000psi.  The tubing is raised 1" off the insulation.
« Last Edit: July 13, 2009, 17:24:22 by mdsalemi »
« Reply #3 on: July 13, 2009, 22:45:27 »
I guess it could also be done with the electrical wiring that is used for under floor heating.  I have just installed it in the concrete slab of my house as it is being built.  It can be brought here by the metre and is not that expensive.  The wiring up by an electrician costs as much and then it is a simple case of switch on and off manually or set it by a thermostat or timer.
1972 MB 280CE Auto RHD 906G
2019 Izuzu DMax 4x4 Slide-on camper.
2022 Volvo XC40 Electric
2024 Volvo EX30 Electric
« Reply #4 on: July 14, 2009, 00:54:33 »
Garry,
The infrastructure for electrical radiant is considerably easier and less costly to install than heated fluid tubes...and at typical US prices for electricity (USD $0.10 per kW/H) it costs a fortune to run.  It's typically only used in luxury bathrooms and the like--not too often outdoors.
A commercial building I once owned was partially heated by these electrical mats, and partially by an electrical-sourced hot water heat pump system.  The building was formerly a service center for the local electrical utility.  We asked how much it would cost to heat it using all the electrical stuff in place.  "About $27,000 per year" was the answer.  Building was 3000 square meters, with a 7000 square meter garage.
We disconnected the mats and converted the heat pumps' hot water system to be fired by oil, and a fraction of that.
« Reply #5 on: July 14, 2009, 01:21:43 »
The way around the high cost of electricity here (to buy is 17c Kw) is to install solar panels on the roof and the electricity that you do not use is fed back into the system and you receive a credit at the rate of 60c kw for the feed in.  Fun watching your meter going backward and a nice feeling that you are somehow saving the planet!) I run a total of 2 kw system and it is almost a neutral power cost for just my wife and I.  We got a total of $16,000 government subsidy for the initial set up so it is a good deal here.  Dont know why more do not take it up in Australia, there is plenty of sun.
All I am waiting for is an electric only car and then it is really getting to be a great deal.  I think GM are going to sell the Volt here next year.
  • USA, WI, Mequon
« Reply #6 on: July 14, 2009, 01:43:33 »
It'd be great to have a heated driveway, Michael.  You will enjoy it.  Out my window at the office, there is a parking lot that is heated.  It only gets plowed on the snowiest of days.  I'm well aware of the costs of plowing, spent over $20k plowing a strip shopping center I own two winters ago and in the teens last winter.
I'm sure it's an energy thing that we can't do it here in my community or city or state.  A friend who has it all mentioned he couldn't do it on his driveway, not allowed.  But, he does have radiant heat in his garage floor with a drain under each car.  Comes in full of snow, dry cars and floors by morning.  Great.
Radiant heat is wonderful, we have electric radiant in two bathrooms and our breakfast (really all meals) dining area with three walls of windows and skylights.  Makes it so much more comfortable in winter and our dog likes it too!
No more of this for you!
« Last Edit: July 14, 2009, 01:47:11 by thelews »
« Reply #7 on: July 14, 2009, 18:29:26 »
John,
If you want it you can do it.  Apparently it was a Wisconsin-only law, but it is now gone.
http://www.heliosinc.net/
If you want some help just call. ;)
'Round here, though, you can't have a floor drain in your garage!  At least last I heard you cant, because they don't want that nasty fallout into the storm drains.  It's OK though, if it comes off the street through the city's storm drains, but you can't connect a floor drain in a garage to sanitary and not to storm either.  At least not without expensive oil separators.
« Last Edit: July 14, 2009, 18:33:54 by mdsalemi »
  • USA, WI, Mequon
« Reply #8 on: July 14, 2009, 19:04:01 »
5 drains.  It doesn't go to the sewer, but to the culvert at the road.
I'll pass on the driveway.  I solved the problem.  My wife does it.  But, she gets off easy, has two nice snowblowers and three nice shovels!
« Reply #9 on: July 16, 2009, 03:52:49 »
A friend of mine owns a chalet in Switzerland where he has a Geothermal heat pump, essentially a long tube into to the earth, in which water is pumped, heated to core temperature and then passed through an exchange to heat a boiler to 60 degrees centigrade. Yes, it is expensive, but once you have it, the heat costs 0 and is ideal for applications such as your driveway (as well as whole house heating). In summer, it even cools if the pipes from the exchanger are laid through the floors.
In the Netherlands, more and more houses are using these systems where allowed.
« Reply #10 on: July 25, 2009, 05:46:30 »
I was under the impression that having your car in a heated ( as in warm ) garage will accelerate the rusting potential if salt is used in your area. As it was explained to me, it's acctually better to leave all that stuff more or less frozen on to your car untill you wash it off at the car wash.
Bringing the car in every night to completely thaw out will leave a salt film on everything and the melting snow will run into every seam carring the salt with it.
Having your car in an unheated area will keep the snow off of it and the windshield clear for moring comutes but will leave all the frozen stuff under the car more or less in place until it falls off on its own.
 As I understand it, the more freeze/thaw cycles you have the faster the rusting can occour.
  What do you guys think?
1988 560SEC
  • USA, WI, Mequon
« Reply #11 on: July 25, 2009, 13:16:13 »
I think you're right, but I wash my car once a week in winter.  My garage is heated to 45 degrees.
I also think no one is listening because they are all at PUB.
Via Manci
« Reply #12 on: July 25, 2009, 14:26:56 »
I'm living in a sea of Conservatives.  What a consoling thought.  If there were any liberals reading these notes we would have been inundated with shouts of global warming and using too much energy.
« Reply #13 on: July 28, 2009, 17:29:15 »
Well, if there are such liberals about (don't really know if politics enters into it) that would complain about such things, what are they doing?
Paying someone with a large truck, perhaps diesel power and questionable tune, to remove the snow?
Spending enormous amounts of time doing it yourself?  My neighbor isn't allowed to anymore--doctors orders.
Throw lots of salt or some other chloride down?
In the snow belt, snow MUST be dealt with, period.  Which is worse, gas for a driveway, fuel for a plow, salt for melting?  Clean burning natural gas for preventing snow accumulation, or a geothermal system, seems just find to me.  Those that want to live with all the snow mucking up their lives, so be it.  Until I can afford that move to climates fairer than here, the snow comes every winter and not dealing with it is simply not an option...I wish it were!
« Reply #14 on: July 28, 2009, 17:49:00 »
Perhaps we should all be entitled to free Universal Snow-Removal....oh wait a minute we have that...
Global Warming  :D
« Reply #15 on: July 29, 2009, 10:24:58 »
Global Warming  :D
Let's see...we have had one of the coolest Julys on record, one of the coolest and wettest Junes.
We had near record snowfall this past winter. http://www.mlive.com/news/index.ssf/2008/03/its_a_record_year_for_snowfall.html
We had, as usual, our share of near-zero temps in January, and winter just as cold as any other.
When is the global warming supposed to arrive here, precisely?  Maybe with those recovery funds?? ;)  I've yet to see either. >:(
« Reply #16 on: July 30, 2009, 16:24:51 »
Let's see....... 10,000 to 15,000 years ago right where I'm sitting right now was covered in a 1/2 mile of ice. You tell me what normal weather paterns are for this area?
1988 560SEC
CraigD
  • USA, WA, Lake Tapps, WA
« Reply #17 on: July 30, 2009, 18:17:29 »
I can say for certain that global warming is here.  It's located in the Pacific Northwest.  1020 Yesterday; 950 in my house at 6:00 pm.  Usually we complain about the rain.  Now we're complaining about the heat.   ::)
Craig
'70 280SL Euro
'55 300S Roadster
'29 Franklin Speedster
'37 Cord S/C Cabriolet (RHD)
« Reply #18 on: July 31, 2009, 03:29:47 »
I'm a bit more certain that nothing realy is....... certain. Several years ago we had a very hot summer with two or three weeks where it was never below 85 degrees here. This year it's hardly even reached 85 degrees. I could say that a nuclear winter coming and based upon some stats and it could be proven.
  Nothing means nothing. We were once convinced that the commies were coming and that you could spot them a mile away. Now it's the newer version of that same old demon knocking at the back door. We have spotter ballons, cameras that watch the border and drones that fly unseen over head looking and watching for what? Global warming? Drugs, terrorists - little green men?
The truth is, you can make anyone believe anything if you tell them often enough. Maybe we do have some affect on climate but it's pure human arrogance to think it's all about us. There was climate change before we were here and there will be long after - it's natural.
If there was no media telling us that we have this problem how many would even notice? The wether around here is different, but not that different.
1988 560SEC
Dash808
  • USA, HI, Kaneohe
« Reply #19 on: July 31, 2009, 09:28:45 »
Good thing we have the media, lol.
Chan Johnson
'67 250sl
Napoli Italian Euro
Bang Bang Booogie!
« Reply #20 on: August 05, 2009, 15:06:16 »
...turn the a/c on and stop complaining! ;)
« Reply #21 on: August 07, 2009, 14:01:40 »
Michael
I think that was one of my father's patens
