I have never been so wound up with the Pagoda since I acquired her ......
Tuesday afternoon I took a lovely drive down to Oxford with the soft top down, after a while I parked up, put the soft top up and went for a coffee.
On my return to the car I undid the two leavers above the window to loosen the roof and then pulled the back leaver to pop the rear window up in order to put the roof back in to its casing. I lifted the casing lid .................
I am not sure what exactly happened, or what I did wrong !! but then the rear window dropped back in to the casing while still open [ not folded ] and the casing lid still up.
Are you still with me ?
The flat roof is able to fold back & forth, however, the rear window refuses to come out of its compartment .....
I tried, I had onlookers try to help, I eventualy had to call 'Naj', Naj explained that I should try using a belt to try to pull the rear window out of its casing, I wasnt wearing a belt
& I didnt have a piece of rope either.
[ Sorry Naj if I misunderstood you & thank you for your time
Over an hour had passed and I decided to call the ''Rescue Team'' It took the rescue man an hour to arrive, could he help NO, did we try using his belt & rope? yes , did it do the trick NOoooooo. We nearly tried using a crowbar!
Due to the weather change and it was suggested that he drive me home on the back of his OPEN truck
Not such a good idea because of the OPEN truck, he then had to call another rescue person with a closed truck in order to get me home, he took another hour & half to arrive.
Cut a longer story short I managed to get home by 12.30am with the rearwindow STILL buried in the back casing unable to fold out/up & the flat roof cant reach the front for me to screw the two srews back in. [ 5 inch gap ]
Can anyone help please ....... :'(
Thank you in advance,
Kemal
280SL
Manual LHD69
