Author Topic: emergency brake cable pulley  (Read 2993 times)
popiex3
« on: July 18, 2009, 22:20:34 »
I need some help to free the pulley for the emergency brake cable. Can I drive the bolt and brass bushing through the housing and replace the bolt and bushing? Or is the bolt threaded through the bushing? The assembly has been soaking in  PB Blaster for 2 days and the bolt still won't budge. Thanks for any suggestions
Re: emergency brake cable pulley
« Reply #1 on: July 19, 2009, 21:57:23 »
If this is a 230 with drum brakes, the original bolt is aluminum and can be easily drilled out.
popiex3
« Reply #2 on: July 19, 2009, 22:07:46 »
Naj, Yes it is a 67 230sl with drum brakes I had thought of drilling,but didn't think to just drill the bolt.Now knowing it's aluminum should make it an easier task. Thanks again
