I have the dreaded sudden differential failure in my 66' 230 SL with an automatic trans., 4:08 diff, and drum brakes. I have a complete 67' 250 SL parts car with a 4 speed standard trans. and disc brakes. Will these interchange? Can I use my existing brake master cylinder with the disc brakes and required proportioning valve. I cannot find where the ratio on the 250 SL diff is stamped, where would that be? Not that it matters now, whatever it is it is.
Also, would it be possible to mount my drum brakes on the new axle, replacing the disc brakes, not a great idea, I know, but it would be an option as my brakes are all new and my replacement axle will require all new brake components.
Or, as another wild option, could I open up the axles and switch out the broken part, the internal UV joint from the 250 to the 230. The axles look different so this is probably not likely.
I have been through several threads about axle changes and it looks pretty straight forward. Is there any info that I should know proceeding into this job that may not be in other threads.
It is going to be a long greasy weekend, Now to start ordering parts.
