I think I'm almost finsihed with my air fuel ratio experiments. For $22.00 I added an accelerometer input to my LM-2 afr meter. With this device I can measure acceleration and use a set of formulas included with the data loging software to estimate rear wheel horsepower and torque. It uses data from the rpm and acceleration channels along with other data that you input. Here is what the formula uses.
Veh wgt 3000 lbs
Tire dia 24.7 inch
Gear ratio of run 2.23
Final drive 3.27
Rpm channel RPM
Acc channel accel
Frontal area 25
Drag .45
Atmosp 29.92
Temp 50
I performed the test in second gear under full accelration from 2000 to 6000 rpms. At 5400 rpms my calculated rear wheel horsepower peaked at 129.3 hp. Torque measured 114 ft lbs.
Torque peaked earlier in the rpm range at 135 ftlbs.
How accurate is the calculation?
SAE Net- In 1972, American manufacturers phased in SAE net horsepower. This is the standard on which current American ratings are based. This rating is measured at the flywheel, on an engine dyno, but the engine is tested with all accessories installed, including a full exhaust system, all pumps, the alternator, the starter, and emissions controls.
SAE Gross-This is the old process that American manufacturers used as a guide for rating their cars. It was in place until 1971. SAE gross also measures horsepower at the flywheel, but with no accessories to bog it down. This is the bare engine with nothing but the absolute essentials attached to it; little more than a carb, fuel pump, oil pump, and water pump. Because the test equipment on the engine is not the same as in SAE net, it is impossible to provide a mathematical calculation between SAE net and SAE gross. As a general rule, however, SAE net tends to be approximately 80% of the value of SAE gross.
As a very general rule, rear-wheel horsepower on a manual-transmission car is about 15% less than SAE net, and rear-wheel horsepower on an automatic-transmission car is about 20% less than SAE net.
So
MB advertised Gross HP for the 280SL 195
Less for SAE net accessories .80%
Less for power train .85%
Adjusted rear wheel hp 132
The Innovate formula set rw hp at 129.3 for my car.
