Author Topic: Windshield how to?  (Read 5366 times)
hill
Windshield how to?
« on: August 13, 2009, 18:08:03 »
Looking for general instructions on installing a new windshield.
Re: Windshield how to?
« Reply #1 on: August 14, 2009, 10:15:43 »
Darryl,
I believe there may be some posts already on this, but here's a quick summary of how I did it:
1. Use a new and OE MB seal!
2. Takes 2 people to do this job
3. Place the rubber seal around the windshield
4. Use a new aluminum trim surround (if possible) and one that IS NOT Bent!  Note: even if order a new one, it may take several reorders to get one that is not bent!
5. While one person holds the windshield (on the floor or bench) gradually install the trim surround into the rubber seal.  I had to use silicon spray to assist with this...  There is a grove in the rubber seal that holds the rear of the trim surround in place.  This is sort of a "lock" grove.
6. Once both sides of the trim surround are installed, lift the windshield onto the car and set the lower end of the windshield in place with the upper end tilted outwards.
7. Install the drivers side wood dash bow (if not already in place)
8. While one person holds the windshield in its outward & tilted position, the second person installs the "pull rope" around the inner lip of the rubber seal.  Use the pull rope to assist with pulling the rubber inner lip into the cabin area
9.  While gradually pulling the rubber seal into the cabin area, gradually start to let the windshield fall backwards and into position.  Gravity will help it to fall into place.  The hard part is to MAKE SURE that the aluminum trim surround stays "locked" in its rubber channel. As the windshield falls into place, it pinches the rubber seal together and locks the aluminum trim surround.  This is why it is almost impossible to remove the trim without removing the windshield (unless it was not installed correctly to begin with, or the rubber seal is old...)
10. As you allow the windshield to fall into place (gravity assisted), it will sort of "pop" into place....
11.  Basically at this point its in and your finished.  Lastly, install the small center trim piece on the top portion of the trim surround.
12. In addition to the rubber seal, I also installed some add'l sealer under the rubber seal as added water tight protection.  Some say this is not needed...  your call..
Good Luck!
Bob  :)
« Last Edit: August 14, 2009, 10:20:59 by bpossel »
graphic66
« Reply #2 on: August 14, 2009, 16:04:00 »
After a few hours trying do as I did,  Call windshield installer.
Allenh
« Reply #3 on: August 16, 2009, 01:58:51 »
Did you have an original seal or aftermarket.  I don't think a dozen monkeys can get it in with a non-original seal.  I did mine myself with a little help from my wife, right by the book.  took less than 10 minutes, and my wife didn't know what we were doing!
Allen
hill
« Reply #4 on: August 17, 2009, 17:53:07 »
Thank you very much for the info one and all. I ended up having it installed by a profe$$ional. With the info at least I did not get gouged to badly. I used a factory seal from the classic center.
« Reply #5 on: August 17, 2009, 23:51:50 »
Hey Darryl, I'd love have the name of your surgeon (now that he's practiced on you!)...
just in case.
hill
« Reply #6 on: August 18, 2009, 00:22:07 »
just in case.
He did a wonderfull job however I can not recomend him. I told him that I do not carry collision on my car and to not drive it. When I came back there was an extra twenty miles on the car.
« Reply #7 on: August 18, 2009, 00:57:48 »
Whoa, that's not too good. It's not like he had to test drive it to see if it fit...
Speaking of windshields, my F-150 truck needs one. A mobile glass guy spotted me in a parking lot and reeled me in. My deductible turns out to be 250. He claims he can put an OEM PPG in for 219? if I want to avoid a claim. I am suspicious. Should I be?
graphic66
« Reply #8 on: August 18, 2009, 02:26:38 »
That's the right price for a windshield, don't pay until it's in, that's all.
