Author Topic: Joe's Rear Axle Replacement tool-  (Read 5797 times)
George Des
« on: August 13, 2009, 20:02:47 »
In one of your posts, you mentioned you had a tool that you use that facilitates re-attachning the rear axle torsion arms to the cones on the underside of the body. I'm contemplating installing a recently rebuilt 3.92 axle and I've been dreading doing it because of the difficulty I had installing the original axle during my restoration. The arms were most difficult to get back up into place. Would it be possible to put up a photo of the tool you use?
Thx
George Desiderio
Re: Joe's Rear Axle Replacement tool-
« Reply #1 on: August 13, 2009, 23:14:49 »
Hi George,
Joe showed me the tool at PUB this year. These are the pictures I took (sorry they are blurry).
He made the tool out of suitably sized exhaust pipe and made cuts on one end so he could curve them inwards, and the welded a nut in there. He also welded a suitable nut at the other end, made to fit the big bolt for attaching the trailing arm.
It basically is very similar to the tool shown in the BBB.
« Last Edit: August 14, 2009, 15:40:27 by waqas »
« Reply #2 on: August 14, 2009, 10:58:46 »
Helo George,
I will take a pic and post it when I get home this evening.
DavidBrough
« Reply #3 on: August 14, 2009, 11:59:49 »
Hi George,
When I changed my rear axle I first tried to fit the trailing arms with the springs in place which proved impossible for me to do so I then fitted both trailing arms without the springs to pull the axle into place and then fitted the springs one side at a time which proved to be straight forward and quite easy to do on my own.
« Reply #4 on: August 14, 2009, 14:10:16 »
David makes a great suggestion to secure the axle and then install the springs one at a time.  It's likely you will need to move the axle forward 1/2 to 1 inch to center it under the cone.  This can be accomplished with a nylon come along or adjustable strap sold in Home Depot.
« Reply #5 on: August 14, 2009, 15:42:27 »
The pictures are now uploaded in my post below. I had technical difficulties when first uploading them, sorry.
I always find that the arms need some lateral movement to get them aligned. I haven't tried the technique of installing the springs afterwards because I typically don't use a spring compressor when working with the rear (except the compensating spring). Might be worth a try next time.
« Last Edit: August 14, 2009, 16:10:42 by waqas »
George Des
« Reply #6 on: August 14, 2009, 16:34:57 »
Thanks, guys. This helps. Will give it a try first w/o the springs installed.
George
