Author Topic: correct color combination  (Read 8578 times)
dean
« on: August 15, 2009, 21:33:59 »
Hello there,
i am new member to this website and the world of SL.  I always admired the Pagoda SL as well as 63-71 SE's.  One day i hope to have both cars!!
Towards that goal, i just purchased a 71 280 SL that needs work sight unseen.   i have not received the car yet but started my homework (admittedly a bit late...) but that is part of the learning process i guess.
First dilemma i face is the color combination.  Based on the pictures of the data card and car i found the below discrepancies:
1. Body and Top code on the data car are 050 (which is white according to the website links on this forum).  The car is red!!
2. The interior is listed 250 which is Cognac leather which looks correct on the car (at least from the pics)
3. The soft top is listed as 746 ( according the the links it is Verdeckstoff 8023 dunkelbraun   Softtop 8023 dark brown)  The current top is beige and damaged which will be replaced with correct color.
i personally have not seen a white car 050 with Cognac interior and dark brown top.  Is this common?  does anyone have this combination?  do you mind sharing pics?
i would have expected the interior to be black with a white car.
what color the steering wheel should be?  it is black on the car now.
i am sure i will have lot more questions as i progress on this project.. but this is just a start.
Thanks for all your help/input.
Best regards,
Dean
Ash
Re: correct color combination
« Reply #1 on: August 16, 2009, 18:01:40 »
Go to www.motoringinvestments.com website for referance photos of these cars. I am restoring a 69 280sl and have found it helpful.
I think white steering wheels were a factory option but black was standard.
Good luck
Ash
« Reply #2 on: August 16, 2009, 18:18:29 »
Dean,
if you have the data card for your car you can check what the original color combination was.
If you don't have it request one from the Classical Center, it is free.
The most frequent combinations are listed here: http://www.sl113.org/wiki/DataCard/RecommendedCombinations
dean
« Reply #3 on: August 17, 2009, 01:10:30 »
HI Ash, thanks for the link.  It is an awesome restoration, unfortunately i cannot afford :(
Alfred, i have a picture of the data card and the color combination is listed as UT 050 OT 050 interior 250 and soft top is 746
which i was able to decipher based on the links in this website as:
outside color white, hard top and hub caps white, interior leather Cognac, soft top dark brown.  This color combo does not appear on the recommended color combo link you advised.
i did some searching and found one car on the registry list of the website to have the same combination as below info:
Christiaan Engelmann 1968 280 SL automatic White (050), Cognac Brown leather, White hardtop / darkbrown softtop 113044 12 006417 2.8 liter Automatic / Becker radio-cassette player / power steering / leather 0 km Within a few months full restauration (4 1/2 years) should be completed.
Unfortunately, i could not find the member info to contact him for photos.
Anyone out there knows Christiaan??
Anyone  has this color combo 050, 746, 050, 250?  would love to see pics.
Dean
« Reply #4 on: August 17, 2009, 04:37:19 »
Dean,
click on "Members" in the bar above and search for members. Search for "Christiaan" and then send him an email through this web site.
And here are 3 pix of a white car with a combination that could be like yours, although no softtop picture:
http://www.pagodentreff.de/diskussionsforum/t176-280-sl-weisse-mercedes-benz-w113-pagode-bj-3-70-a.html
Aug. 17: Pictures added.
« Last Edit: August 17, 2009, 20:16:25 by 66andBlue »
dean
« Reply #5 on: August 17, 2009, 15:01:25 »
Thanks Alfred.
I did Friend Christiaan's info and sent him an email.  hope to hear from him.
the link you listed takes me to a German site that apparently i need to register to access the pics.  could not navigate my way around. :(
in any event thanks for your help.
i was able to find the attached pics that looks like similar color combos.  Hard to tell if the body is white or ivory though.
dean
« Reply #6 on: August 17, 2009, 20:17:03 »
Dean,
I added the pix to my previous post.
« Reply #7 on: August 18, 2009, 07:34:20 »
This is Christiaan and his car...
dean
« Reply #8 on: August 18, 2009, 18:14:00 »
Pete/Alfred,
Thanks for the pics.
the color combo 050/250/746 looks good!
i guess when it is time to do a repaint willl bring her back to her original colors instead of red.
Dean
dean
« Reply #9 on: August 30, 2009, 00:54:46 »
Hi Alfred,
I finally got the car today. YEAH!!!!!!!
It is in much better shape than i anticipated.  I need to get the engine fixed first and then will see what else is needed.... Stay tuned.
re the color, I found on it the note as:
Surinam Red Metalic
Paint Code K8135K
DuPont Chroma base
I did not find this color listed in the manual.  Is it a MBZ color?
The color is not bad and looks like they did a full body paint on the car from what i can tell.
Dean
« Reply #10 on: August 30, 2009, 09:09:55 »
Congrats... pictures please...
and no, that does not look like an original Mercedes Benz color... those were supplied by Herberts or Glasurit (http://www.sl113.org/wiki/DataCard/PaintCodes)
dean
« Reply #11 on: August 30, 2009, 16:54:56 »
Thanks Pete,
Now the fun begins.....  She is at the shop now.
Here is a picture of the color.
dean
« Reply #12 on: August 30, 2009, 19:35:05 »
Dean,
This one is a 571 H if that helps.
Probably original UK dealer fitted Radiomobile Radio and 8 track too!
« Last Edit: August 30, 2009, 19:41:00 by naj »
dean
« Reply #13 on: September 02, 2009, 01:54:13 »
Thanks Naj for the pics.
If and when the car Will be needed a pint job i think i will go back to the original color white 050.
until them the burgundy color is not bad at all.
dean
