Author Topic: Mounting the floor dimmer switch  (Read 3030 times)
Largeowner
« on: September 02, 2009, 15:00:55 »
Hello All,
I am in the process of removing the old carpet and padding in my 67 230 SL.  While removing the carpet on the drivers side (left side), I found that the previous owner had left the dimmer switch detached and held in place only by the carpet itself.
The firewall threaded holes appear intact, and I would like to reattach the dimmer properly.  I am wondering if any members know which size machine screws should be used for this application?
Thanks for the help,
Large
Re: Mounting the floor dimmer switch
« Reply #1 on: September 02, 2009, 19:45:57 »
4mm sheet metal screws (self tappers)
N 007983 004332 from MB
Largeowner
« Reply #2 on: September 02, 2009, 19:54:01 »
Thanks Naj,
That helps a great deal!
Large
