Author Topic: removable top handles  (Read 7067 times)
Jim Donati
« on: September 09, 2009, 05:22:33 »
My 1970 280SL has two chrome removable handles that are used to lock/unlock the soft top and hard top to the top of the windshield.   Did all W113 models (starting with the 230SL) all have the same removable handles like mine?  I thought I saw a picture of an earlier model that showed the handles were permanently attached to the latches.
I also want to know if there was a pouch or sleeve that came with the car when new to store the two handles in when not in use.  currently I have mine stored in a vinly case intially used to store eyeglasses.  8)
thanks
« Last Edit: July 01, 2010, 14:53:13 by Donati »
Re: removable top handles
« Reply #1 on: September 09, 2009, 09:31:54 »
Not sure the exact date of the change but about the time of the many "safety" features mandated by USA rules implemented for the mid-250SL's and later, the built-in handles for the tops were changed for removeable handles.
Cars came with two handles in a vinyl holder that is now quite scarce and farily costly when available.
A set of attached handles can easily be substituted for removeable handles.
I've had cars with both and the attached handles are a lot more convenient especially when trying to put up the soift top in a sudden shower.
Richard M, NYC
case
« Reply #2 on: September 09, 2009, 18:04:35 »
Top handle admirers,
Yes, that's correct.
My parts list says the following:
113 776 06 17 - Verschlußgriff - 250 SL from #005089, 280SL from 000007 - 012192
107 776 00 17 - Verschlußgriff (lock handle) - 280SL from #012193
Strange ...
I don't know what about the serials between 250SL #005090 and 280SL '000006; pats list doesn't say that.
Both parts are still available new. Around €uro 80.00 in Germany.
(parts & knowledge collector - does have far too few parts & no knowledge)
Jim Donati
« Reply #3 on: September 09, 2009, 19:55:22 »
Does anyone have a picture to share of the original pouch for the removable handles?
treedoc
« Reply #4 on: September 09, 2009, 21:53:58 »
Hi Donati,
See below, pouch is made from two layers of thin vynal sheets with a thin, about 2 mm thick layer of foam sandwiched in between and then heat pressed / welded. Oh, and no mine's not for sale.
Hope this helps.
Treedoc
« Last Edit: September 09, 2009, 22:38:07 by treedoc »
Jim Donati
« Reply #5 on: September 10, 2009, 03:43:31 »
Treedoc:
thank you for sharing.  I was not expecting anyone to sell theirs, but I was hoping someone like you would be kind enough to help me understand what I was looling for.
thanks again
Jim
« Reply #6 on: September 10, 2009, 19:13:19 »
Jim,
Mercedes (Daimlerchrysler or now Daimlerwithoutchrysler) made a reproduction of this pouch and it was at a reasonable price (€ 15.00 or something). It's a while ago so I don't know whether it is still available.
You might want to ask Tom Hanson from Mercedes-Benz Classic Center in Irvine, CA.
Good luck,
Andres G
  • USA, FL, Miami
    • Toyota Adventure Team
« Reply #7 on: September 14, 2009, 03:08:15 »
I might add that you can opt for the not-so-costly pouch from the W107, there's got to be tons of those around.
Good luck.
Andres
« Reply #8 on: July 01, 2010, 11:40:03 »
Does anyone in the UK have a pouch they could lend me?
« Reply #9 on: May 29, 2011, 14:39:32 »
Seeing as we are in repro mode at the moment... I originally asked the question above as I was wondering about some repro handle cases for the younger cars...
bogeyman
  • USA, NE, Omaha
« Reply #10 on: May 29, 2011, 14:46:33 »
Gernold has them available - $35.00
Rick Bogart
1969 280SL Silver(180)/Green
1993 500E
1972 350SL
1995 E320 Cabrio
jameshoward
« Reply #11 on: May 29, 2011, 16:18:05 »
James,
I'm up for some handle pouch repro action. Alas, I don't have one to copy from.
JH
James Howard
1966 LHD 230SL
mbzse
Re: removable top handle pouches (M-B repro part)
« Reply #12 on: June 11, 2011, 16:17:30 »
Quote from: 114015
../..Mercedes made a reproduction of this pouch and it was at a reasonable price (€ 15.00 or something)
Yes, seems to be available from Mercedes dealers. The part No is: A 113 776 01 86  at a price of 17,28 €
/Hans in Sweden
« Last Edit: June 11, 2011, 16:19:03 by mbzse »
/Hans S
