Waqas, the 905mm belt length is what I got from my local MB parts guy when I requested a belt for an alternator mounted in the original factory location, i.e. "low". I wonder if, and I suspect that, a longer belt may be used with the original York compressor with the alternator mounted above. And perhaps that belt measures 935 and that length was simply carried over when the Sanden was installed in your car. If that's the case, someone may have unintentionally avoided the trouble I went through until I finally got it right.
